1975 Allis Chalmers Engine Specs
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: 1975 Allis Chalmers Engine Specs
    Posted: 26 Sep 2018 at 7:30am
From the desk of the Dr.  Please make a sticky if possible.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2018 at 8:58am
Should be moved to Knowledge based.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2018 at 10:09am
That's a great AC spec sheet! Thanks Dr. Thank you Coggonobrien for sharing a photo of it.
What does "Trans?" stand for in Trans pump press? Transfer??
Interesting how the Lcombine's 2900mkII spins 200rpms & has 10hp more than 7000's 2900mkII.
Edited by AC7060IL - 26 Sep 2018 at 10:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2018 at 10:25am
All HP ratings are FLYWHEEL HP, not PTO.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2018 at 8:53pm
I wonder why the 860 Cotton Stripper is the only one missing information?
Another probably dumb question...what's the difference in a 2800 and a 2800 MK 1? Or the difference in a MK 1 and MK 2 for that matter.
Edited by CrestonM - 26 Sep 2018 at 8:54pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2018 at 9:00pm
Trans pump pressure is injection pump transfer pressure.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2018 at 9:14am
On the 3000 series 426 engines, Mark 2 was the new generation which began with the 7030/7050 tractor. That meant upside down oil filters and a DM-series injection pump.  Also was crankshaft driven engine oil pump only. The older 3000 series were in the D-21/210/220 .  They had DC injection pumps, oil pump was either way and turbo was center mounted on the ex manifold. The blocks were different between the two engine series.   The 2000 series 301 engines are a little confusing. Anything Mark 2 for sure had the copper injector tubes in the cylinder head. Injection pump may have been a DM-4 or a Simms in-line. Mark 1 may have been making reference to a crankshaft driven engine oil pump?? and dual oil filters?? like the 200 tractor had?
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2018 at 2:17pm
Nice Piece of Historic AC documentation - vote for inclusion in knowledge base.
Orangeman
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2018 at 10:01pm
I have a 2800, color yellow, industrial power unit that has a DC injection pump, crank driven oil pump and dual oil filters. The decal on the radiator says Mark I as well as the data plate with all the catalog numbers on the engine block. So I'd say Doc you are right again!, Mike
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2018 at 6:24am
What does the exhaust color " V H" stand for?  Some of them have an asterisk or 2 behind them.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2018 at 7:37pm
I always assumed it stood for Very Hazy.  None of those engines were very clean burning at that point in history. When they went to Bosch Injectors in 1980 or so, things cleared up a bit over the AC injectors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2018 at 9:23pm
Thank you
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2022 at 1:17pm
Very good info. I was going ask about the V.H. as well.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2022 at 12:27am
Van Halen !!!  Beer
