1975 AC 200
Message Reverse Sort Order
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Topic: 1975 AC 200
    Posted: 11 May 2020 at 9:22pm
I went from axle mount rim mount on my 7050. If you get in mud with axle mount, there is a good chance you will break a value steam off when mud falls through. Haven't fix a flat tire since.          MACK
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 9:09pm
on a 100 series I like wide rears makes them look like wheatlands
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 12:33pm
Hmmph! Here I've had clamp on duals for years, and sitting wishing I had hub mount duals cuz I thought they were the "stuff".
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 12:08pm
Didn't IH have trouble keeping centers tight on axle back then?
My brother in law has run clamp on triples on 4840 JD since new. Must be pretty good centers.
Yes IH had lots of trouble keeping wheels tight on the axles.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 10:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 10:19am
IH rear wheel centers are made like Swiss Cheese...full of holes. They break fairly easily.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2020 at 9:52am
Originally posted by MACK MACK wrote:
Rim mount, unless you have a IH.        MACK
Why IH?
Wink
I am a Russian Bot
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 9:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 6:52pm
hub for row crop....band for added traction...my preference
acplowboy45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acplowboy45 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2020 at 1:16pm
What everyone prefer hub duals or t rail
Edited by acplowboy45 - 10 May 2020 at 1:22pm
