1975 AC 200 ???"Transbooster???
Mr.Dogg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mr.Dogg Quote  Post ReplyReply Direct Link To This Post Topic: 1975 AC 200 ???"Transbooster???
    Posted: 31 Mar 2010 at 10:06pm
My buddy picked up a 1975 200 cheep, he was telling me about it and asked if I knew what a "transbooster" was. He said it was written on a lever on the floor I believe. I was not sure what he was talking about, is this like a tourque amplifier? Can anyone help out a couple of wanna-be farmers.
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 10:10pm
IS HE SURE IT DIDN'T SAY TRACTION BOOSTER
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 10:15pm
I was thinking traction booster too. If so, it is a torque amplifier, draft control, goes by different names depending on manufacturer. Helps keep tractor from spinning out by "bumping" the lift up a little when heavy load is detected, and then back down.(if set properly)
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 6:00am
Mr.Dogg, The best thing you can do is get an owners manual and read it. It sure helps. That way you can tell the capacitys and what each control does as well a adjustments.
"Burgie"
Charlie (NC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie (NC) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 6:52am
Traction Booster is basically a draft control system for the hydraulic lift.  It also boosts traction by shifting weight from the implement to the rear wheels of the tractor.
The "TA" on AC tractors is called a "Power Director" and it simpler, stronger and all around better than the Torque Amplifiers (TA) that IH used.  It is basically a double wet clutch that gives you a low and high range in each gear.
This page was generated in 0.131 seconds.
