1969 HD16DP f/r selector issue |
Charly1067
Topic: 1969 HD16DP f/r selector issuePosted: 15 Jun 2020 at 8:49am |
I finally got this 16 running last night after sitting for 8 years,but I cant get it to go into gear. I can select forward or reverse but cant pull the lever back to 1st or 2nd gear. Is this a frozen linkage issue? Or do I have bigger problems. Also the blade raise and lower lever is froze up. Any advice would be helpful.
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4874 |
Posted: 15 Jun 2020 at 1:37pm |
I know nothing of your transmission,but since the blade control lever is froze it seem reasonable that other linkage is stuck as well. So start spraying your favorite lub and wiggling and tapping on things to get things moving.
