1969 C 10 headlights |
Page <12 |
Les Kerf
Posted: 6 hours 59 minutes ago at 2:58pm |
I'm afraid I did not adequately explain myself; the 'Zero resistance to ground' to which I was referring is from the Ground side of the headlight bulb all the way back to the Negative battery terminal. In a First Approximation Theory, this is considered to be Zero Ohms; in reality, there is always some resistance, even in a brand-new vehicle. In a vintage vehicle, the actual ground path can have 'significant' (meaning enough to be noticeably detrimental) resistance. Again, a voltage drop measurement taken from the ground terminal of the light bulb all the way back to the Negative post of the battery will tell the tale. Installing relays to deliver maximum voltage to the headlights is an excellent way to improve lighting in vintage vehicles.
Joined: 11 Sep 2009 Location: illinois Points: 88865 |
Thanks(1)
Posted: 4 hours 17 minutes ago at 5:40pm |
actually EVERYONE is right !!
![]() Alternator to ground will show max available. head light terminal go ground will show what was lost from alter to the light thru WIRE. both head light terminals will show what is going THRU the bulb whats LEFT is the loss on the bulb OUTLET to the GROUND CABLE... everything in the system can have some LOSS... and being 50 years old, that can be sugnificant on ANY WIRE and ANY TERMINAL connection.
Page <12 |
