1969 C 10 headlights
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2025 at 2:58pm
Originally posted by BuckSkin BuckSkin wrote:
...if you have a zero resistance path to Ground, you are not going to get an accurate reading of true available voltage...
I'm afraid I did not adequately explain myself; the 'Zero resistance to ground' to which I was referring is from the Ground side of the headlight bulb all the way back to the Negative battery terminal.
In a First Approximation Theory, this is considered to be Zero Ohms; in reality, there is always some resistance, even in a brand-new vehicle. In a vintage vehicle, the actual ground path can have 'significant' (meaning enough to be noticeably detrimental) resistance.
Again, a voltage drop measurement taken from the ground terminal of the light bulb all the way back to the Negative post of the battery will tell the tale.
Installing relays to deliver maximum voltage to the headlights is an excellent way to improve lighting in vintage vehicles.
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2025 at 5:40pm
actually EVERYONE is right !!  Clap
Alternator to ground will show max available.
head light terminal go ground will show what was lost from alter to the light thru WIRE.
both head light terminals will show what is going THRU the bulb
whats LEFT is the loss on the bulb OUTLET to the GROUND CABLE...
everything in the system can have some LOSS... and being 50 years old, that can be sugnificant on ANY WIRE and ANY TERMINAL connection.
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2025 at 8:14pm
 I am reading this thread with great interest as I too am struggling to cobb onto some decent headlight replacements for the Halogens.
 My 2015 F150 came from factory with Halogen lights and after 10 years have failed miserably and after reading many articles and it seems a simple changeout to LED lights is not possible without adding additional electrical wiring and pieces,,,,
 I have talked to some owners that bought their trks new with the Halogen lights and the lights were sorry when new,,,they too want better replacements,,,,
BuckSkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuckSkin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2025 at 8:33pm
2015 is way too new for my understanding.....; does your truck have real Sealed Beam Head-lights or those milky plastic head-lights with separate bulbs ?
I have relayed the modern style on various vehicles belonging to other people with great results, but not so impressive as a good set of Sealed Beams.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2025 at 10:01am
 OH,, I would Love to get some of those old timer sealed beam headlights for my trk,,but don't think the engineers of today would allow that as no money in things that last too long,,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2025 at 10:10am
Can buy 6014s in Halogen these days.
