1968 HD 4 shuttle clutch worn out?
Thulsa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thulsa Quote  Post ReplyReply Direct Link To This Post Topic: 1968 HD 4 shuttle clutch worn out?
    Posted: 08 May 2011 at 7:02pm
Hello all. New guy here.
I've got a 1968 HD 4 with a backhoe attachment and bucket loader. It's been good to me and I used it quite a bit last year with almost no problems.
The last few times I used it, it began to feel like the clutch was beginning to slip. Sometimes it would take several seconds to shift, sometimes it would shift but slip under load, sometimes if I rev'd up the engine it would work a little better but when I finally parked it last fall, I barely got it into the barn. It's definitely something that happened over time, as opposed to all at once.
It slips in all gears (3 speed), and both forward and reverse. I started it up the other day and I got it to move 30 foot or so, but it definitely needs to be fixed before I can use it again.
I have a manual and I plan to check the pressure/s, although the manual isn't exactly written for a layman.
Is there anything else that it could be besides a worn out clutch? How do I check it? Any ideas or advice would be greatly appreciated.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 11:56pm
It is a clutch pack and a torque converter , so slippage could be from wear in the fwd/rev clutch plates or even from low converter pressure.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2011 at 8:26am
I don't want to insult your intelligence, but nor do I want to overlook the obvious; Is the oil level up to snuff? Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thulsa Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2011 at 4:55pm
The fluids look good to me. The tranny fluid is at the low end of the crosshatches on the dipstick though. I'll make sure I put some in before I start tearing things apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2011 at 6:30pm
Check all your pressures , change filter, and be sure it is full.
This page was generated in 0.227 seconds.
