1968 D15 seriesII rebuild
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: 1968 D15 seriesII rebuild
    Posted: 03 Jan 2021 at 7:20pm
Our dads D15 developed a knock recently as well as low oil pressure if going down a hill. Charlie pulled it in the shop yesterday and we began to diagnose its issue. He had checked the compression last week and the 2 middle cylinders were around 15 lbs lower than 1 and 4. 132,116,117,134 if I remember correctly. So we went after the oil pressure issue first by dropping the pan. Not good news, the sump pickup was laying in the pan. Unsure how it had come loose from pickup tube as the keeper is still attached. No shavings in the pan which was good news. So that explains the drop in oil pressure going down hill. Engine has never been apart and has been a really good and reliable tractor. Pulled the head to check cylinders only finding a slight ring groove which is normal. Pulled the rod caps and there was some wear but no scouring until we got number 4 piston out. Bearing had some damage but the crank wasn’t gouged. Not taking any chances, will be pulling the crank out to have a look at it. Can’t feel any scouring with a finger but will need to mic it for rebuild kit anyway and possible repair. Haven’t pulled the mains off yet. Looking for suggestions of a good quality rebuild kit, sleeves, pistons, rings, gasket kit.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2021 at 11:01pm
This is a G160 since do not see wires for headlights.. sources for kits are limited to one or two as it is a rather rare engine.  sn 9001 and up - rods do not have small end clamp type pin retainer but rather full floating wrist pins.  Just make sure get quotes on  G160 engine.  I am assuming the cotter pin cam out of the floating pick up. Have seen this once before. Two things to check here that are unique to this series.  Inspect the pin in the end of the cam shaft at rear that drives the pump , if it has wear and is loose it will be a source of oil pressure loss, check closely. Also rebuild and inspect the oil pump closely since it has been run dry at times.  This pump has a relief valve ball and spring as does the front of the cam... look at a parts break down and repair accordingly. IF you do go the complete route also note that the center cam brg is special and has to have the holes lined up to oil the rockers.  These engines oil through the center of the cam to the rest of the engine.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2021 at 11:20pm
I believe there is only 1 manufacturer of the G160 kits, (aftermarket) prolly in china, tiawan or india no matter who you buy though. Although I just checked now, and it looks like I can get OEM pistons and sleeves, possibly the whole OEM kit.
I just rebuilt a D15 G160 engine and I have some advice on the cam bushings, which you always replace if block comes out of tractor. In your set of new cam bushings, the center one will NOT be drilled correctly. The little hole in the bushing that must line up with the little hole in the cam and again in the block is drilled on the wrong half of the bearing! Whoever installs the cam bushings must be very sharp to redrill the small hole in the correct spot!
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 4:36pm
Thanks to both of you for your responses. It is a 160-14458R engine. Serial number D15 24633, purchased new 7-19-1968. Will be checking on kits after we get the crankshaft checked so we know what bearings will need to be ordered. It’s a shame this happened as it’s always ran well. Still need to figure out how the sump came loose from the pickup tube.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 4:40pm
Alex, who was the manufacturer of the kit you used? I have never heard of having to modify bearings before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2021 at 4:33pm
you need bearings and rings and a good inspection... Do you really need piston and liners ? ........... just a thought.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2021 at 5:06pm
Yes, piston #4 has some side damage probably due to the low oil pressure that occurred while going down hill. The bearing also showed some damage. Other 3 have a little marking on the sides but we are not going to take any chances. While its down she will get the whole rebuild. This tractor has been a work horse for us for 52 years, everything from a 3 bottom plow, disk, corn picker, sickle mower, hay rake duty, bailing hay, pulling the allcrop 60, wagon mover, and any other chore that you can think of. It was dads main tractor until he bought the 6060 in 1981. Used to farm over 200 acres back then. Hopefully our children and grandchildren will get another 50 years out of her.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2021 at 5:34pm
GOOD PLAN !! Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2021 at 6:12pm
The cam bearings were federal-mogul, which is a good USA brand, although some of their bearings are made in Mexico. There must have been a tooling mistake, that little oil hole is supposed to be offset to the front and it is drilled offset to the back, or vice versa.
If you go all the way into the engine, the motor kit that I offer is $600. Includes pistons, sleeves, o-rings and rings. It is made in the USA!
Edited by Alex09(WI) - 05 Jan 2021 at 6:32pm
www.awtractor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2021 at 8:33am
We are at the point to remove the engine. What is the correct procedure to remove the front end? Remove the front axle and roll it out and use a chain hoist to support steering pedestal so it can be removed? It looks like the 4 bolts attaching the power steering need to be removed so the bolster can be pulled forward. Our manual is very vague in the disassembly process.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2021 at 8:35am
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2021 at 12:18pm
Pulled the engine out of my Series 1 D 15 back in July . There's a post somewhere on here , but I'm thinking most of the pics are gone . Might be of some help if you can find it .Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2021 at 1:44pm
We rolled the axle out and used the chain hoist to hold the bolster. Came out fine, no issue really from there. Just a tight squeeze at the power steering assembly. Have the engine out, sleeves removed. Crank definitely needs to be checked.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2021 at 2:31pm
Glad everything is going well so far .
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2021 at 2:55pm
We put the oil float pickup back on to see how it came off. If the carter key is in a certain position it will slide off. Wear of 52 years has worn it slightly and it will slide by. Really a poor design IMO. Sure caused some serious damage. Piston is from #4 as well as the crank position. A good days work, great spending time with my 2 brothers as we take care of dads 1st AC tractor that he bought new in 1968. No major problems in countered so we are happy. A pretty normal overhaul and she will be ready to go for hay season.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2021 at 5:11pm
AC720Man,
Great that you and your brothers are working on this together also. Thanks for the update!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2021 at 7:33pm
Might want to enlarge the cotter pin hole to use a bigger pin so the pickup doesnt work its way out again. Looking good!
www.awtractor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2021 at 7:26am
Tbran, you are correct, it is a interesting oil pump. The sweeps appear to be fine as well as the cup that it rides in. Haven’t removed the housing yet as I am quite nervous about the springs of the sweeps flying out. I guess the cover and 3 small cover screws could be placed back on and then remove the pump itself to inspect the pin at the end of the cam as you recommend. Will be cleaning everything up to send to the machinist.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2021 at 12:36pm
When I had the engine out of my D 15 the oil pump pick up had what looked like steel wool in it ? Does yours ? Thanks !
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2021 at 2:47pm
Yes it does, I guess it’s a mesh screen to help keep debris out of the pump. I’ve seen it used as air filters before also, at least ones that are oil bathed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2021 at 4:30pm
Rick if you have read the post you know we will need one of your awesome clutch packages while we have it apart.
Edited by AC720Man - 10 Jan 2021 at 4:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2021 at 4:49pm
Good to know . Thanks
Tom IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2021 at 2:47pm
AGKITS has the overhaul kit they are Reliance
structures View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2021 at 6:05pm
If it's of any use there are some pics of my D15II engine rebuild on page 4 here:
page 5 has the cam bearing that I had to drill out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2021 at 10:37pm
Robert I just went through your post on your D15 and I must say your a gifted and talented man. Very impressive work. Some good information that we can use for sure. Thanks for letting me know. And can’t wait to see the final product.
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2021 at 7:44am
Hey thanks.  I appreciate that.  I assure you I am not gifted or talented.  I just jump in face first, screw up alot and do it again!  Looking forward to following your build here.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2021 at 8:37am
AC720Man,
Thanks for the update on your 15! These can take some time but well worth the effort if you like these quirky old orange machines!
Good to hear from Robert! I didnt know he was lerking! His work was a inspiration for me and others as he brought back his fathers D15. A great build thread!
We need more pictures!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2021 at 7:36pm
We removed the cam and all the lifters yesterday. Bearings look good but they will be replaced anyway. Cleaned the inside of the engine of all the sediment of years of antifreeze circulation around the sleeves. Wasn’t too bad considering its 53 years old. Rear cylinder in the corner of the head had the most. Only had one issue. We went to remove the water pump and it was stuck on the stud that goes into the block. PB blaster, some heat would not budge it. It was rusted to the housing. Not enough threads to lock 2 nuts together. It eventually snapped off just inside the block. The stud had to be driven out of the pump once removed. Bolt is soaking in BP blaster. Easy out only turned it slightly. So before that snaps off will just soak and wait. Will put Kroil on it tomorrow as I have had better luck with it versus BP blaster.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2021 at 7:42pm
I hate broken bolts, but on equipment as old as we are working on its expected. Good luck getting that rascal out of there! The one I just took out of the F40 had just enough to weld a washer to the bolt then a nut to the washer. I let it cool and worked it back and forth to get it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2021 at 8:01pm
Got the bolt out this evening...a little soaking and time did the trick. Waiting on parts, to be continued.
