1967 Allis Chalmers I400 Industrial Tractor Loader
mick1994 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mick1994 Quote  Post ReplyReply Direct Link To This Post Topic: 1967 Allis Chalmers I400 Industrial Tractor Loader
    Posted: 29 Jul 2024 at 6:18pm
uploads/24978/450226858_8052871444734597_4489225457048202879_n.jpgHi All,
Hoping to find a new home for this 1967 Allis Industrial 400 loader and backhoe. It works perfectly and does not leak fluid. The temp and amp gauges and paint and finishing touches need attention for sure.
Comes with both 12" and 24" excavator buckets, loader pallet forks, service manuals, and some spare parts. , All sheet metal present including battery and tool box.
12 volt positive ground system and power steering.
The following repairs have been done:
-All fluids and oil changed
-Chassis and moving parts greased
-New oil and new hydraulic filters
-Tune Up: New Spark plugs, cap, rotor, wires, points and condenser.
-New ignition coil
-New starter
-New solenoid
-New Battery
-New battery cables
-New voltage regulator
-New fuel strainer and lines
-Carburetor completely rebuilt with Bronze throttle bushings machined and pressed
-New air inlet hose
-Fuel tank cleaned and epoxy sealed
-New fuel gauge float
-New brake drums, shoes, bearings, and seals.
-New water pump
-New radiator and hoses
-New thermostat
-Front tires newer and in excellent shape
-New Muffler
-New Exhaust manifold gasket and surfacing
Probably more that I am forgetting
Have photos and receipts for work.
Located in Alexandria, Virginia. Asking $8,000
Edited by mick1994 - 10 Sep 2024 at 4:17pm
