1965 allis chalmers d12
Kevin01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin01 Quote  Post ReplyReply Direct Link To This Post Topic: 1965 allis chalmers d12
    Posted: 04 May 2024 at 10:43am
I have a 1965 Allison chalmer and  i have been trying to find what type of oil i need to fill transmission, rear end and final drive.  There was a form that is was reading the guy was using a napa brand (premium heavy duty tractor hydraulic & transmission fluid). I was hoping to get some input on this.
Edited by Kevin01 - 04 May 2024 at 4:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2024 at 6:28pm
Just use Universal Transmission/Hydraulic fluid for a newer tractor.  Specs to meet AGCO/Deutz-Allis/Allis-Chalmers 821 or 821XL or PermaTran.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2024 at 9:12pm
any GOOD quality trans / hydraulic fluid should meet the spec... Some call it Universal Tractor fluid / Hy Trans / Transmission- Hydraulic fluid... etc... You should be able to get it at any Farm Store , Wal Mart, NAPA, etc...  just look at the back and make sure it meets a DOZEN different specs for FORD / IH/ ALLIS / JD.... that should be the good stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2024 at 9:16pm
this is on the back of the 5 gallon bucket at Wal Mart... does not specificaly list ALLIS 821 , but meets all the other Companies, so it is "GOOD".
This Super Tech Heavy-Duty Tractor Hydraulic and Transmission Fluid is specially formulated with only the finest quality, high-viscosity index base oils and an advanced and rigorously tested additive system to deliver unsurpassed protection and performance. It offers exceptional protection against wear from microscopic contaminants and higher operating temperatures and pressures, and ensures long equipment life. This Super Tech transmission fluid contains critically balanced frictional characteristics that ensure precise clutch and wet brake operation with unsurpassed chatter suppression. It also prevents acid formation for exceptional protection against rust and corrosion and meets the following requirements: Allison C-4; John Deere J20A/B/C, J21A, Hygard J14 B/C, Type 303; Case JIC-145, Hy-Tran, MS-1207, 1208, 1209 and 1220; Caterpillar TO-2; Deutz Allis; Ford New Holland ESN-M2C134-D; International Harvester HY-Tran B-6; Kubota; and many more.
Edited by steve(ill) - 04 May 2024 at 9:18pm
