1965 190XT tachometer question.
6wheeler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 6wheeler Quote  Post ReplyReply Direct Link To This Post Topic: 1965 190XT tachometer question.
    Posted: 11 Mar 2025 at 2:17pm
Hi all. Playing with my 190xt again. It is now running well. The tach does not work and I can't find anything in my books on how it works/drives. I am guessing it would drive off of the distributor base. Is there supposed to be a cable for it? The tractor is showing 3957 hours. Which obviously, are not current. It is not important. I just like to have things working. Maybe the head unit is junk. I don't know that yet. I am sure some could be electrical. I would guess this tractor is old enough to not have that. I am not doing a restoration on this tractor. I am a patina guy. The tractor looks great to me. When I figure out how to post a picture of it. I will. Thanks  Pat
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2025 at 3:57pm
Tach is not electric. Cable driven off the engine. Diesel engine has a drive on the left side. Not sure where it is on the gas engine, but without a cable, your tach will not work.
Cable might also be broken inside - mine was. Replaced the cable and everything worked again.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2025 at 4:07pm
It drives off the cam / oil pump - mid block - the gas has a 90 degree plug on the distributor base that contains the tach drive mechanic and male threads for the cable. 74054851 IS THE PLUG     parts.agco
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2025 at 8:17pm
Most likely broken cable, easy to check. Unscrew it from the tach, start the tractor and see if it’s turning. Star Speedometer in FL will make a new cable or repair the tach. Not cheap, but he guarantees them for a year. He has repaired 4 for me and they look new when I get them back. I highly recommend him.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 6wheeler Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 1 minutes ago at 9:56am
How did you find that number? I went on the sight and it doesn't recognize that number. It doesn't recognize the tractors serial number 190 5960 either. Maybe I am doing it wrong Ouch
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 52 minutes ago at 1:05pm
Star Speedometer is great, but I heard he recently retired
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 47 minutes ago at 10:10pm
He is still repairing, he just restored my D14 tach. Called him last week to get him to make me a new cable. Arrived today and I called him to let him know I received it. We talked for a while, he is doing well and didn’t mention retiring anytime soon although he told me last year he was thinking about it. He still enjoys repairing our old stuff. Thank goodness he does.
This page was generated in 0.095 seconds.
