1963 D grader engine
Max-AC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Max-AC Quote  Post ReplyReply Direct Link To This Post Topic: 1963 D grader engine
    Posted: 14 Oct 2020 at 9:13am
Hi there, i am wondering if i have the OEM engine in my grader...number stamped being carburator on the block says 17-32992-M...my grader is a 1963 square tube...
On the oil filter side there is an gas pump...I ve been told on industrial machine that they used gas pump... I think the engine would be the same as D17? Thanks. Max
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2020 at 11:05am
The D I have is the old round frame one -----not sure about what the newer ones have for engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2020 at 1:27pm
The older model "D's" would have had a WD or WD45 engine. By the late 1950's they went to the D-17 engine, which is reflected by your serial number 17- xxxxxx.
