1962 HD6 dozer steering
Curtis L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Curtis L Quote  Post ReplyReply Direct Link To This Post Topic: 1962 HD6 dozer steering
    Posted: 27 Aug 2016 at 1:16pm
Hi, I'm adjusting the steering bands on a HD6. The cavity was full of water. Are they made to be oil bath or run dry? Thanks in advance
donoman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donoman Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2016 at 2:57pm
If you can easily access the steering bands then it is a dry backend undo the drain plugs under each steering compartment, you may need to flush out with a solvent to get rid of the oil and grease which would have come up with the water, if you are not using near water leave the plugs out.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2016 at 3:27pm
These machines have dry stering cluch and after removing the plugs and draine you could start the machine and pull your 2 stering cluch levers and angaged the transmission and the master cluch than the stering cluch will turned free for dry the discs
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2016 at 7:59pm
Use the search feature at the top. There are many posts about the steering clutches. If the compartment was full of water they are probably
frozen. The brake band is on the steering clutch drum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Curtis L Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2016 at 11:55pm
Thanks. Had to remove the fuel tank and covers to access them to adjust the bands anyway. Thanks again
