1958 HD 6 Crawler Injector Pump Rebuild
tzale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tzale Quote  Post ReplyReply Direct Link To This Post Topic: 1958 HD 6 Crawler Injector Pump Rebuild
    Posted: 06 Sep 2016 at 9:50am
Looks like I have to pull my injector pump and have it rebuilt.(No fuel pressure)
1. Can anyone suggest a company that knows what they are doing in regards to a rebuild?
2. I know I have to retime the engine, does anyone have any instructions on how to do this? The books I have do not address this.
Thanks in advance
Ted
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 10:24am
im guessing this is an American Bosch Psb pump?     good luck finding someone to work on it
Post Options Post Options   Thanks (0) Thanks(0)   Quote tzale Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 11:12am
Yes it is AB pump PSB-4 model
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 11:54am
Taylor diesel in north little rock Arkansas was still rebuilding some a few years back
Post Options Post Options   Thanks (0) Thanks(0)   Quote tzale Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 11:56am
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 11:58am
did you check to see of the transfer pump is working?  it should be bolted right to the side of injection pump
Post Options Post Options   Thanks (0) Thanks(0)   Quote tzale Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 12:32pm
I have not tinkered any more with it, the manuals I have are in pretty rough shape
It did run for about 10 min,had enough pressure to blow out one of the supply lines.
Then i pulled out the engine shut down lever and was never able to get any fuel pressure back in the system
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 12:40pm
pull that little cover off where the kill rod is,  it may have popped off inside.  very simple fix, just a rod with a washer on the end that catches the end of a lever.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tzale Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 12:43pm
I did pull the lever out it was attached with a spring and flat stopper and it looked ok, will actually pull ocver off this weekend looks like two 7/16 bolts
Edited by tzale - 06 Sep 2016 at 12:43pm
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2016 at 7:36pm
Some of them pumps will stick after using this ultra clean diesel fuel... I have a Case 500 that the pump will stick in the shut off position.  In those old tractors with the PSB pumps, I dump part of a quart of oil in the tank too.
 Check the governor rod where that little side cover is and see if the lever moves FREELY.
  Also ma metering valve will get stuck sometimes too down in the pump... and a possible stuck pressure relief valve at the pump area.... Check fuel tank and shut off valves and filters...
Post Options Post Options   Thanks (0) Thanks(0)   Quote tzale Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2016 at 9:05am
I will do a "field" stip and hopefull7y it is somethoing minor like this
This page was generated in 1.215 seconds.
