1957 AC D-14 Decal Placement Questions |
Post Reply |
MattSplittgerber
Silver Level Joined: 15 Nov 2011 Location: Temple, Texas Points: 81 |
Posted: 15 Nov 2011 at 3:41pm |
I am almost finished with the restoration of a 1957 Allis Chalmers D-14 for my dad. It was his first tractor at 11 years old. I would like the decal locations to be as accurate as possible. I have scoured the internet as well as made several phone calls trying to get this right. I am a little confused and any help would be greatly appreciated.
1. I have seen the Power Crater Engine decal centered under the carb, but also offset to the right under the carb (as you look at it). Which is correct? 2. I have seen the Snap-Coupler decal on the bell under the tractor on your left side if you were sitting on the tractor. Is this correct? 3. I have not seen where the "Replace oil filter when crank case oil darkens" would go. Any advice? 4. "Lowering Adjustment." I have seen this on the left side panel under the fuel tank in a diagram. Is this correct? 5. I have no idea where the "Allis Chalmers Parts" decal would go. Any advice? 6. I have no idea where the "Oil Filter Element" decal would go. Any advice? 7. I assume the "Service Daily" would go on the air cleaner right above the oil cup. Is this correct? 8. Lift Lower and the Traction Booster should go on handles on the steering wheel. 9. "Drain here" should go behind carb. 10. I have no idea where the "Remove cover to grease clutch shifter" should go. Any Advice? 11. Not sure where "Warning, before dismounting, shift transmission into neutral. Disengage PTO." Any Advice? 12. I am not sure about "Shift Pattern." The gear numbers are cast into the top of the tranmission. Maybe on fender or gas tank? Any Advice? 13. "Be careful" probably goes on PTO Shield. Any Advice? 14. "Danger pull only from drawbar." Any Advice. Thanks for any help in advance. It is greatly appreciated. Matt Splittgerber 254-541-5605 |
Rick of HopeIN
Orange Level Joined: 11 Sep 2009 Location: Hope, Indiana Points: 1324 |
I like your paint job, I love the 57 decal designs. These pic show some decals you asked about. Some parts are not original, the hood is wrong, this is really a 57...
If I get it inside I can shoot better pics... Edited by Rick of HopeIN - 15 Nov 2011 at 6:47pm |
Rick of HopeIN
another
MattSplittgerber
Thanks Rick! Does your tractor have any of the warning decals or the others that are still readable? Thanks again for the help, I will post the final product pics when I complete it.
Chalmersbob
Orange Level Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
the decal about the oil filter with the element # on it goes around the oil filter can, after you paint it orange. Bob
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7355 |
You have some decals that are not used on a D14...
Remove cover to grease clutch shifter Shift pattern decal 1 and 2 are correct.Not sure about 3. 4 is correct - goes around the hole that is in the panel. 5 - no comment 6 goes on the oil filter 7-9 are correct 10 - not used 11 - goes on throttle quadrant 12 not used 13 goes above PTO shield 14 goes on the PTO shield
MattSplittgerber
Thanks DSeries4. Greatly appreciated.
MattSplittgerber
Thanks Chalmersbob. Would you have a separate oil filter to put on at a tractor show? I plan on lightly working this tractor.
DonDittmar
Orange Level Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2484 |
Picture taken from an original D15 Series 2. Drawbar warning decal was on lift arm housing
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
MattSplittgerber
Thanks Don. Does anyone else have any pictures of exact decal placement on a D- Series tractor.
79fordblake
Orange Level Joined: 01 Jul 2010 Location: West Kentucky Points: 827 |
Picture of Power Crater Decal on '60 D14 I did for neighbor. |
Rick of HopeIN
pic of DANGER decal on back of 57, normally under my 3 point link bracket
DonDittmar
Thats right Rick. My series 2, the one in the above pic, has factory 3pt so if they put that decal there it would be hid.
MattSplittgerber
Thanks guys, anymore pics? Keep em coming.
MattSplittgerber
Does anyone know where the "Allis Chalmers Parts" or the "Change Oil" decal would go exactly?
Rick of HopeIN
Sorry for the delay, I have not been out to shop much in daylight.
PS: I think the Use Allis Parts decal was for your checkbook cover Edited by Rick of HopeIN - 20 Nov 2011 at 11:01am |
Rick of HopeIN
another
Rick of HopeIN
#3
79fordblake
I think those decals should actually be on the traction booster and lift-lower levers. |
Dave (Mid-MI)
Orange Level Joined: 12 Sep 2009 Location: Hemlock, MI Points: 544 |
According to sales literature from 1959, the lift-lower and traction booster decals go on the levers like Blake said. They look to be about 1/2" away from the rubber tips on the levers. The same brochure shows the PTO warning decal centered on the quadrant above the steering wheel shaft. Couldn't find any pics of decals in earlier literature. Seems like many times the early brochures are pics of prototype tractors which don't necessarily have all the decals in place.
Rick of HopeIN
That makes sense on the lever decals, my tractor has been repainted so maybe not a good example.. If i repaint mine I will probably be asking these same questions. I have never seen a good guide for the D series.
Post Reply | |
