1956 D14
Message Reverse Sort Order
JH Buck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JH Buck Quote  Post ReplyReply Direct Link To This Post Topic: 1956 D14
    Posted: 03 Mar 2011 at 8:00pm
The D14 is a great tractor
denno View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote denno Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 4:23pm
Thanks guys, will check those things, i appreciate the advice
denns
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 9:44pm
No such thing as a 56.  Make sure the clutch is adjusted properly.  There should be 1/4" between the fingers and clutch plate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 8:23pm
Make sure the foot clutch pedal has at least two inches minimum freeplay at the pedal footrest. Remove stop bolt washers or thread the clutch rod inward to possibly adjust.
Post Options Post Options   Thanks (0) Thanks(0)   Quote denno Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 7:53pm
Hi
looking over my paperwork that came with tractor, it is a 1957 i think.  Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote denno Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 7:27pm
Hi ALL
Wondering if someone has some advice.  My 1956 AC D14 is in great shape, runs great, looks great.  I know nothing about the clutch in these tractors.  Lately, seems like clutch is slipping.  Makes no difference if I am in high or low range.  It is getting worse.  As I work the tractor, like plowing snow, it does get better but still slips.  Is this something I can fix with an adjustment?  thanks in advance,   Dennis
