1953 CA w/ Snap Coupler
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: 1953 CA w/ Snap Coupler
    Posted: 15 Feb 2026 at 10:56am
I have been keeping an eye out for Snap Coupler CA parts. All of my CA implements are pin hitch, but with the 4 row toolbar planter I am building, I'm worried a CA might not be able to handle quite that much weight based on feedback from the forum. It would be nice to set the planter toolbar up for Snap Coupler and be able to just hook that planter up to a WD/45 if I find out the CA can't handle it. Cue the search for the CA Snap Coupler hitch parts and I found this 1953 CA for sale and dragged it home.
The one rear rim disintegrated when we winched it onto my trailer. There was a can over the exhaust but it's stuck solid. I think I have gotten lucky once in my life with soaking the cylinders in diesel and actually breaking an engine loose. Might do that just for kicks while I work on the other tractors and the planter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2026 at 11:05am
Since I have accumulated 5 cheap/rough CAs now, you start noticing things:
-All 5 have Zenith carburetors. I have yet to see an MS carb on one in person but I know they exist.
-All have the higher compression ratio gas engines.
-4/5 had at least a couple of cultivator brackets left on them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2026 at 2:29pm
Great find on a CA with SnapCoupler that may run with a little work.
As with most anything 70 some years old, Some things get changed.  As per the parts book, only a Zenith carburetor was OEM on a CA. However any carburetor from a B,C. RC. D10/12 will bolt to the manifold. What is the Spec number on the M/S you have seen on a CA?
My guess is that few Distillate or High altitude CAs were sold.
The CA is a wonderful cultivating tractor and the mounting brackets and levers don't interfeer with most other CA implements.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2026 at 4:28pm
The AGCO parts book shows a TSX-486... But if it's not in your parts book, maybe the MS carb was only offered as a service replacement sometime after the CA was out of production? I.e. trash or lose your CA's Zenith carb in the 1970s and AC sold you a complete TSX-486 as a replacement?
I am sure looking forward to cultivating with one of mine. You are more optimistic than me about getting this one running quickly, but I will certainly try.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2026 at 4:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2026 at 6:40pm
Yes, my mistake. It's the D10/12 tractors that only used a Zenith. How ever of all of the CAs I've acquired over the years, not one had a M/S on it when I got it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2026 at 8:58pm
I wonder if they were only very late production, maybe? Or just used to fill in if Zenith couldn't keep up with demand? It would be interesting if anyone on here has a fairly original CA that they know or believe originally came with an MS carb, and what the serial numbers are.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2026 at 6:21am
Nice find wjohn! Lots of good looking parts on that one.
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2026 at 9:06am
My original 1952 CA (13092) came with a TSX-486.
1952 CA13092
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2026 at 9:30am
I have two CA's with snap couplers, if you can find the side weights for it, I don't think lifting it would be a problem unless this planter is super heavy.  But for sure a tricycle front end without the side weights is a bit lite on the front end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2026 at 10:03am
Good find on this CA. It will take some $$$ to get it going and looking good but the satisfaction will be worth it. It will make a very nice tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2026 at 11:16am
And/or wheel weights which are pretty cheap and easy to find.
1952 CA13092
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2026 at 11:48am
In my area the CA side and front weights are pretty scarce and not cheap even though there are a good many CA tractors around
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2026 at 11:56am
CA tractors are quite rare in northern Idaho and accessories are even more scarce. Allis-Chalmers never attracted a large following around these parts Cry
Judging from the used tractors around here it seems that Ford couldn't haul them in fast enough.
Edited by Les Kerf - 16 Feb 2026 at 11:58am
Matt Tallant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2026 at 8:47pm
I have a #3 mower on a CA if interested I’m in southern VA
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2026 at 10:58pm
Thanks Mike. Maybe 20 years from now I will have a CA that looks half as nice as yours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2026 at 11:39pm
I am hoping to lift 4 #74 row units on a toolbar and I know that will be asking a lot. I do have a couple sets of front wheel weights laying around. I have a pair of C side weights but no CA side weights.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2026 at 11:40pm
Interesting, thank you. You're pretty confident it was never replaced?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 7:06am
C side weights can be made to work on a CA with a piece of pipe for a spacer and a longer bolt
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 5:42pm
Completely.  The service manual seems to imply that MS was more common than Zenith.  I tend to suspect that many of those with Zeniths were originally MS.  If they have 161J part numbers, probably original, but if they have 12522 part numbers or similar, probably a switchout.
I think that TSX-486 and 470 are the same except 486 has a drain petcock on the float bowl.
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 8:34pm
Thank you very much for that info. If I wind up needing them to keep the front end down I can make that happen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 8:47pm
That is interesting. My CA owner's manual is Form TM46D (which must be a later one, since it has the later AC logo) and it only shows pictures of the Zenith carb, and only shows a parts diagram for the Zenith carb. Perhaps you are onto something and the earlier tractors had MS?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 49 minutes ago at 11:14am
Edit: AGCO website does not seem to corroborate the kerosene theory but does not provide any indication that a kerosene engine is available (like indicated in the service manual).
Don't know that this is correct or complete but several different sources show this same data.  One site seems to indicate that Zenith 161 carbs were used primarily on low compression kerosene-capable engines and TSX on the gasoline only engines.  You could get low compression engines for a CA as an option.
Edited by dfwallis - 12 hours 10 minutes ago at 11:53am
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 57 minutes ago at 10:06pm
I haven't seen a single list of carb application numbers for AC tractors online that I actually trust. I can poke a ton of holes in that list at Norfar (but I have had good experiences buying parts from them). I have two TSX-670 carbs that would only fit a CA if you had a different manifold with a larger mounting flange. I am fairly certain they came off of a D-series tractor of some sort (D14 maybe?), but that's not shown in the list. There are other numbers that are clearly wrong too.
161J7 is just a sort of a high level... model number, maybe, is how to think of it? I don't believe you will find any carb that actually has 161J7 on the ID tag. It will have the 11141 or 11142 numbers on it in my experience. The spec number on the tag is what varied as built by Zenith, with specific jet sizes, vent sizes, venturi sizes, etc.
This page was generated in 0.071 seconds.
