1953 CA w/ Snap Coupler |
| Author | ||
wjohn
Topic: 1953 CA w/ Snap CouplerPosted: 15 Feb 2026 at 10:56am |
I have been keeping an eye out for Snap Coupler CA parts. All of my CA implements are pin hitch, but with the 4 row toolbar planter I am building, I'm worried a CA might not be able to handle quite that much weight based on feedback from the forum. It would be nice to set the planter toolbar up for Snap Coupler and be able to just hook that planter up to a WD/45 if I find out the CA can't handle it. Cue the search for the CA Snap Coupler hitch parts and I found this 1953 CA for sale and dragged it home.
The one rear rim disintegrated when we winched it onto my trailer. There was a can over the exhaust but it's stuck solid. I think I have gotten lucky once in my life with soaking the cylinders in diesel and actually breaking an engine loose. Might do that just for kicks while I work on the other tractors and the planter. ![]() ![]() ![]() |
| Sponsored Links | ||
wjohn
Posted: 15 Feb 2026 at 11:05am |
Since I have accumulated 5 cheap/rough CAs now, you start noticing things:
-All 5 have Zenith carburetors. I have yet to see an MS carb on one in person but I know they exist. -All have the higher compression ratio gas engines. -4/5 had at least a couple of cultivator brackets left on them.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5243 |
Posted: 15 Feb 2026 at 2:29pm |
Great find on a CA with SnapCoupler that may run with a little work.
As with most anything 70 some years old, Some things get changed. As per the parts book, only a Zenith carburetor was OEM on a CA. However any carburetor from a B,C. RC. D10/12 will bolt to the manifold. What is the Spec number on the M/S you have seen on a CA? My guess is that few Distillate or High altitude CAs were sold. The CA is a wonderful cultivating tractor and the mounting brackets and levers don't interfeer with most other CA implements.
wjohn
Posted: 15 Feb 2026 at 4:28pm |
The AGCO parts book shows a TSX-486... But if it's not in your parts book, maybe the MS carb was only offered as a service replacement sometime after the CA was out of production? I.e. trash or lose your CA's Zenith carb in the 1970s and AC sold you a complete TSX-486 as a replacement? I am sure looking forward to cultivating with one of mine. You are more optimistic than me about getting this one running quickly, but I will certainly try.
Joined: 11 Sep 2009 Location: illinois Points: 90077 |
PaulB
Posted: 15 Feb 2026 at 6:40pm |
Yes, my mistake. It's the D10/12 tractors that only used a Zenith. How ever of all of the CAs I've acquired over the years, not one had a M/S on it when I got it.
wjohn
Posted: 15 Feb 2026 at 8:58pm |
I wonder if they were only very late production, maybe? Or just used to fill in if Zenith couldn't keep up with demand? It would be interesting if anyone on here has a fairly original CA that they know or believe originally came with an MS carb, and what the serial numbers are.
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4252 |
Posted: Yesterday at 6:21am |
Nice find wjohn! Lots of good looking parts on that one.
dfwallis
Posted: Yesterday at 9:06am |
My original 1952 CA (13092) came with a TSX-486.
1952 CA13092
Trinity45
Joined: 17 Mar 2014 Location: Kentucky Points: 2107 |
Posted: Yesterday at 9:30am |
I have two CA's with snap couplers, if you can find the side weights for it, I don't think lifting it would be a problem unless this planter is super heavy. But for sure a tricycle front end without the side weights is a bit lite on the front end.
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6597 |
Posted: Yesterday at 10:03am |
Good find on this CA. It will take some $$$ to get it going and looking good but the satisfaction will be worth it. It will make a very nice tractor.
dfwallis
Posted: 22 hours 50 minutes ago at 11:16am |
And/or wheel weights which are pretty cheap and easy to find.
1952 CA13092
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3171 |
Posted: 22 hours 18 minutes ago at 11:48am |
In my area the CA side and front weights are pretty scarce and not cheap even though there are a good many CA tractors around
Les Kerf
Posted: 22 hours 10 minutes ago at 11:56am |
CA tractors are quite rare in northern Idaho and accessories are even more scarce. Allis-Chalmers never attracted a large following around these parts ![]() Judging from the used tractors around here it seems that Ford couldn't haul them in fast enough.
Edited by Les Kerf - 22 hours 8 minutes ago at 11:58am |
Matt Tallant
Posted: 13 hours 19 minutes ago at 8:47pm |
I have a #3 mower on a CA if interested I’m in southern VA
wjohn
Posted: 11 hours 8 minutes ago at 10:58pm |
Thanks Mike. Maybe 20 years from now I will have a CA that looks half as nice as yours.
wjohn
Posted: 10 hours 27 minutes ago at 11:39pm |
I am hoping to lift 4 #74 row units on a toolbar and I know that will be asking a lot. I do have a couple sets of front wheel weights laying around. I have a pair of C side weights but no CA side weights.
wjohn
Posted: 10 hours 26 minutes ago at 11:40pm |
Interesting, thank you. You're pretty confident it was never replaced?
Gary Burnett
Posted: 2 hours 60 minutes ago at 7:06am |
C side weights can be made to work on a CA with a piece of pipe for a spacer and a longer bolt
