1953 CA w/ Snap Coupler
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: 1953 CA w/ Snap Coupler
    Posted: 20 hours 52 minutes ago at 10:56am
I have been keeping an eye out for Snap Coupler CA parts. All of my CA implements are pin hitch, but with the 4 row toolbar planter I am building, I'm worried a CA might not be able to handle quite that much weight based on feedback from the forum. It would be nice to set the planter toolbar up for Snap Coupler and be able to just hook that planter up to a WD/45 if I find out the CA can't handle it. Cue the search for the CA Snap Coupler hitch parts and I found this 1953 CA for sale and dragged it home.
The one rear rim disintegrated when we winched it onto my trailer. There was a can over the exhaust but it's stuck solid. I think I have gotten lucky once in my life with soaking the cylinders in diesel and actually breaking an engine loose. Might do that just for kicks while I work on the other tractors and the planter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 43 minutes ago at 11:05am
Since I have accumulated 5 cheap/rough CAs now, you start noticing things:
-All 5 have Zenith carburetors. I have yet to see an MS carb on one in person but I know they exist.
-All have the higher compression ratio gas engines.
-4/5 had at least a couple of cultivator brackets left on them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 19 minutes ago at 2:29pm
Great find on a CA with SnapCoupler that may run with a little work.
As with most anything 70 some years old, Some things get changed.  As per the parts book, only a Zenith carburetor was OEM on a CA. However any carburetor from a B,C. RC. D10/12 will bolt to the manifold. What is the Spec number on the M/S you have seen on a CA?
My guess is that few Distillate or High altitude CAs were sold.
The CA is a wonderful cultivating tractor and the mounting brackets and levers don't interfeer with most other CA implements.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 20 minutes ago at 4:28pm
The AGCO parts book shows a TSX-486... But if it's not in your parts book, maybe the MS carb was only offered as a service replacement sometime after the CA was out of production? I.e. trash or lose your CA's Zenith carb in the 1970s and AC sold you a complete TSX-486 as a replacement?
I am sure looking forward to cultivating with one of mine. You are more optimistic than me about getting this one running quickly, but I will certainly try.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 20 minutes ago at 4:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 8 minutes ago at 6:40pm
Yes, my mistake. It's the D10/12 tractors that only used a Zenith. How ever of all of the CAs I've acquired over the years, not one had a M/S on it when I got it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 50 minutes ago at 8:58pm
I wonder if they were only very late production, maybe? Or just used to fill in if Zenith couldn't keep up with demand? It would be interesting if anyone on here has a fairly original CA that they know or believe originally came with an MS carb, and what the serial numbers are.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 27 minutes ago at 6:21am
Nice find wjohn! Lots of good looking parts on that one.
This page was generated in 0.295 seconds.
