1951 WD |
Page <1 678 |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8089 |
Sleeving the bores would beat any metal build up process. Not cost effective. Get another block.
wjohn ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: KS Points: 1834 |
Thanks to all for the block advice. I picked up another block from a forum member before Christmas. Just got it back from the machine shop where it was dry stripped/blasted, decked, and cleaned. They said they had to take 0.005" off, so I'm anticipating I'll have to take a little off the tops of new the sleeves in order to have the right protrusion above the deck.
They did point out some tiny cracks around one of the 3/8" stud holes for the cylinder head. It looks like there's still a broken off piece of stud way down in the bottom of it so I'll carefully set this up in the drill press and take care of that. The shop wasn't concerned about the cracks and I'm not really either, but I may get a pic of it later this week. No cracks in between the cylinders anywhere.
I was not planning on putting any new paint on this tractor but since I had the block stripped, I had to put something on to keep it from rusting. Cans of PO #1 are almost $20 each from AGCO now. ![]() |
Over a year later
![]() I got a parts washer and I hate to think how many days of cleaning up parts over my life I could have saved. The WD's hydraulic pump has been the first big cleanup job in it. Overall the pump was in far better shape than I expected - not much moisture had been sitting in it. However, I did find some scoring in one of the bores of the pump body. I can catch my fingernail on one of them. I will do my best to polish this out with Scotch-Brite or similar, unless I'm wasting my time? ![]() ![]() |
I'm crashing onwards with the pump. Everything is cleaned up and I picked up most of the parts I needed. Just waiting on a few that my dealer didn't have in stock. I ended up doing some light filing plus Scotch-brite work to clean up the worst scores in the bore, and some damage to the rearmost control valve sleeve. I noticed two small mangled pieces of metal in the parts washer today that probably caused the damage. I'm not sure where they were hiding at, but that's why it's always good to thoroughly clean everything, right? Files in control valve bores like this is a huge no-no but I figured I didn't have anything to lose on this pump. We'll see if it works out. There were 7 shims on the unloading valve. I decided to leave all of them in. I need to get a 5000 psi gauge so I can check pressure once I have the tractor back together. ![]() The AC service manual says you should replace the unloading valve as an assembly. However they are no longer available in 2024. They also provide a procedure "for emergencies" for reusing an old unloading valve with a new ball. You are supposed to press the ball into the seat with 5000 pounds of force and then clean up any deformation in the hole afterwards. I pressed gently with a 20 ton hydraulic press - maybe I only actually got 1 or 2000 lbs. of force on it, but I didn't want to overdo it since I don't have a pressure gauge on my press. ![]() |
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 3546 |
You know what they say, necessity is the mother of invention!
Right! It continues...
I am hoping someone can help me with this linkage from the drawbar - anybody have one loose laying around their shop that can take a measurement of where the hole for the crosspin should be located? The shaft came loose from the external arm at some point in the tractor's life and they (poorly) welded it back on, and the welds broke. I have the shaft out, cleaned up, and ready to weld back in but I don't want to mess up the hole orientation. The way the crosspin holds the internal linkage to the shaft seems like it would be important. The first pic shows how it was when I removed it, and I suspect that is not correct. EDIT: Second pic shows the shaft backwards. Luckily it is not welded yet, ha. ![]() ![]() Edited by wjohn - 21 Apr 2024 at 1:35pm |
Sorry, don't have one loose. Hopefully someone else will.
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8216 |
Is this what your looking for
That's it!!
Mikez that sure is an unloading valve! Neat to see that there's at least one NOS one still around. I am hoping mine is fine but I put in a new ball to be as sure as I can. There's no visible damage, at least.
70224506 would be the PN of the regulating shaft assembly, in case you have one loose and can show how the hole in the shaft is oriented relative to the plate it is pressed into. Otherwise I might be SWAGing it based off of what I can see in the parts book diagram... which is not very scientific.
I found a picture of a NOS regulating arm for the hydraulic pump linkage online, so between that and the part book illustration I'll take a stab and hopefully the alignment will be close enough.
I've been working on the block. It's all washed out (again) and I've put some of the small fittings etc. in, and dropped the first liner in tonight. Protrusion came out to ~.010". The machine shop said they took .005" off when they decked the block, and spec is .002-.004" so I figured I may have to take a little off the tops of the liners. However I may need to keep on scraping the seats in the block based on looking back at some of the posts on here. The AC manual says to use a file to take material off the top of the sleeves. I'm hoping I can come up with something better than that.
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8172 |
John,
Sounds to me like your making good progress! Scraping the seats for the liners, Yes I remember doing that on the WD45 block. Don Bradley was coaching me over the phone on that build. He kept telling me that I needed to scrape the seat more, and he was correct. I kept getting material from that area. I think I ended up at .004. My block may not have been machined. I would think the machine shop would have bored the seats .005 deeper? Maybe this thread will get me motivated to work on my CA puller? Thanks! Regards, Chris and Cheryl
Good to see you checking in Chris! I know you have been busy. Yes, the machine shop decked the block, and we discussed the counterbores at the time. They were not extremely familiar with wet sleeve engines but are a very competent race shop in our area. I decided I would machine the sleeves down after the fact instead, but maybe in hindsight I should've given them the sleeves so they could've checked and counterbored at that time.
I am off to go scrape those counterbores some more and figure out how much I need to take off the top of each liner. If I can't figure out a good way with my tools then I am sure they will do them for a reasonable amount since I had them do my block work.
Thanks, and go get at that CA! |
I would take liners and sleeves to machine shop and have counterbores set where they belong.
I couldn't find a shop that would do the counterbores for less than $500, so I picked one and dropped the block (and liners - thanks SteveM) off the other day with the .002-.004" protrusion spec from the AC service manual. The dollars sure are adding up.
Then I ran across this for sale for not much over $500: ![]() It's a dinosaur of a Kwik-Way boring bar, but I'm hoping that for under $1000 invested I can get it cleaned up a little and get the right cutter tips to do counterbores. That would pay back after doing 2 blocks. I can't deck blocks in my shop so I will still have to farm that out, but that's not too expensive. After that gets done, if needed it would be great to cut the counterbores myself. Plus I have a number of small engines to do and none of the shops seem too interested in messing with those. We'll see how many years it takes me to actually get this thing all set up, ha.
wjohn, keep us updated on how this goes for you. Looks like a fun toy to have in the shop.
Mike, if/when I get the time to clean it up, I'll do a separate thread for it. I may be missing something but it sure seems like it should be handy for the counterbores. Then I also got to wondering if I could cut out where the liner o-rings seal, and buy sleeves already made from somewhere. Then I'd have my original block fixed back up. I need to do some research first to see how that sleeving process works. I know guys over on the red forum have that done now and then.
I got the block back from the machine shop about a month earlier than they had told me to expect, so that was a nice surprise. I need to double check the liner protrusion and then clean it up again, and finally start assembly.
Page <1 678 |
