1951 CA narrow to wide front swap?
Hunt4Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Topic: 1951 CA narrow to wide front swap?
    Posted: 10 Apr 2019 at 2:39am
I bought a wide front end and wonder if there's any info out there in regards to how to go about doing this swap out?
I am looking for possible step by step instructions...
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2019 at 11:57am
If you have the CA wide front it is a take off and bolt back on.
First jack up to take the weight off the front wheel from under the torque tube where the wishbone connects.
You remove the hood, the radiator shell, the radiator, remove the nut from the front steering arm and link. You are down to the four bolts holding the bolster to the block.
The wide front can roll under the tractor lining up the wish bone and the four studs in the block. Put back what you took apart and your good to go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2019 at 1:05pm
Thanks Dick for the info!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2019 at 4:40pm
If your a bull like I used to be you can do it yourself. I ran into a situation a time or two that it would have been best to have help. Now I need help to remove the key and put it back in.
