1950 WD loader install |
Post Reply |
RickJ
Bronze Level Joined: 12 Sep 2009 Location: Portland OR Points: 7 |
Posted: 4 hours 41 minutes ago at 12:57pm |
Hey guys restoring I believe it might be called number nine loader for my 1950 WD - any body have a photo best way to hook up hydraulic hoses with shutoff valve
Gary
Orange Level Access Joined: 13 Sep 2009 Location: Peterborough,On Points: 5404 |
There are 2 ways I have done this. The 2 rear lift cylinders are fed from 2 separate Ports on the Factory Valve located ahead and to the right of the Battery Box. One way is to remove the R/H hose and 'T' it in with the L/H hose connection. In the now MT R/H Port connect a Ball Valve and connect the single hose from the loader Lift Cylinders to this Valve. Open this Valve when you want to use the Loader. The rear lift Cylinders will raise to the top and remain there. When you want to use the rear lift cylinders, raise the Loader to about 3 feet off the ground, then close the added Ball Valve. The loader should remain at that location and the rear lift cylinders will be operable. G |
Post Reply | |
