1949 Model D Motor Grader |
TumblingIQ ![]() Bronze Level ![]() Joined: 28 Mar 2017 Location: Nevada Points: 18 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Apr 2017 at 2:27pm |
My oil filter assembly is missing the stem that goes up into the oil filter. My question is will a wd 45 oil assembly bolt right on the 201cu engine? or my other choice is: Can the stem be removed from the wd 45 oil assembly and screw right into my oil filter base. Appreciate any help I can get.
45 turboa- ![]() Orange Level ![]() ![]() Joined: 04 Feb 2012 Location: coral city wi Points: 441 |
WD & WD45 have the same filter base the stem pulls out of the filter base not theaded .
turbocharged
Thanks for the reply. Do you know if the wd or wd45 oil filter assembly will bolt right on the the model d grader with the 201cu engine?
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54123 |
WD motor is in the early d grader. Ergo, it will fit...
