1949 Allis Chalmers WD project |
Page <123> |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4063 |
Posted: 18 Jan 2021 at 11:03am |
I thought having CRS, cold rolled steel was a good thing. I keep a supply around here for repairs that pop up. Or did you mean Can't Remember S***? I'm guessing the later, seam to have plenty of that too!
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 939 |
Posted: 19 Jan 2021 at 9:46am |
I took the manifold off and broke a stud which luckily it just broke the threads on the end off.
I also got some Persian #1 paint and also Hardener/Catalyst for hardener from Van Syckle. |
55allis
Posted: 07 Mar 2021 at 9:41pm |
Have it about ready to paint but still haven’t figured out a way to have it on a stand for painting with the tires/rims and frame rails off.
plummerscarin
Posted: 07 Mar 2021 at 10:04pm |
Maybe try drilling and bolting channel iron to the bell housing like I did? The part you miss painting could be touched afterwards and covered by the frame rails anyway.The final drives are on jackstands now. Move them out to the hubs for paint.
55allis
Posted: 20 Apr 2021 at 2:09pm |
I finally got a chance to work on it the other day and ended up taking a car stand and putting it under the angle iron that is under the engine on the front. I got both frame rails and the front wheels off.
As I was talking to my cousin, we got talking about getting front mud scrapers that they was a rare option from the factory?
55allis
Posted: 24 Apr 2021 at 9:20pm |
I found the “mud scrapers“ in a local barn.
55allis
Posted: 06 May 2021 at 10:56pm |
Does anyone have a opinion about self etching primer?
I’ve never really have tried it on anything to know if it’s worth the time and money. |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5217 |
Posted: 07 May 2021 at 10:39am |
I use self etching primer on all of mine followed by gray primer. Seals the metal to prevent rust. I have been very pleased with the results.
55allis
Posted: 11 May 2021 at 11:41pm |
I might than put it on everything I sandblasted.
For a update on the tractor, I got the one tire off to get the rim welded on, I also got a picture of it down below.
ac hunter
Posted: 12 May 2021 at 7:17am |
55,
Just be very careful when you are working on that tractor with the wheels off / disassembled. I always thought the ones I worked on that way were top heavy and kind of clumsy to handle. Wouldn't want a mishap. Looks like you are making good progress.
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3915 |
Posted: 12 May 2021 at 10:06am |
I'll second AC hunter's comment about safety. I notice you are using concrete blocks to support the tractor. And they are set in the weakest orientation to bear weight. They are a disaster waiting to happen as they can suddenly break with no warning. There have been guys badly injured or killed due to this happening. I would highly recommend that you get some solid wood blocking or heavy duty axle stands to support your tractor!! We want to be able to see the progress on this project continue!
55allis
Posted: 12 May 2021 at 10:45pm |
I do have a safety stand under where the drawbar goes.
I also taped/painted up the hydraulic hoses to the snap coupler rams
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8476 |
Posted: 13 May 2021 at 7:26am |
I built a frame for the back of the tractor to support it where the rock shaft attaches. I must say you need to be very careful with these perched on blocks. As others have mentioned wooden blocking is safer and steel members bolted to the tractor frame or structure are safer. We just want you around for a long time!:)
Lots of moves to make on your WD. Keep going! Here is a shot of my support system. Frame in back and steel saw horse in front. Any time your lifting any or moving it it can shift and move. ![]() Here is a shot where I was going to do the final painting so the second steel saw horse went under the rear end. the frame came off and I set the rear down on two bolts threaded into the underside. then set this down on the bolts. At this point it could still tip and get out of balance. Use caution! ![]() Regards, Chris
Edited by Sugarmaker - 13 May 2021 at 7:28am |
55allis
Posted: 18 May 2021 at 2:49pm |
I got it mostly primed but now I’m stuck waiting for the humidity to go down. It has been raining about every night just enough to keep the humidity up.
Sugarmaker
Posted: 19 May 2021 at 9:53pm |
Looking real good! Thanks for the update!
Regards, Chris
55allis
Posted: 19 May 2021 at 10:11pm |
Today I got it painted and I love it!!!
ac hunter
Posted: 20 May 2021 at 2:37pm |
Looks shiny. Bet you can't wait to get it assembled. Keep up the good work and pictures.
55allis
Posted: 27 May 2021 at 10:29pm |
Got a question, where to get oil pressure gauges that are just like the original? I ordered one from tractorpartsASAP.com and it is NOT ANY WHERE CLOSE to the original.
Sugarmaker
Posted: 28 May 2021 at 8:07am |
Looking good on the paint! Yes your going to like the look! New gauges do leave something to be desired. Not sure there are any better ones?? Maybe some one knows more about these than me. Your doing good on the WD!
Regards, Chris
garden_guy
Joined: 05 Jul 2013 Location: Illinois Points: 1150 |
Posted: 28 May 2021 at 9:23am |
Looking incredible! I got my new oil gauge from Steiner but didn't take a pic before it was installed. Will try to remember to take a pic. I did get my new temp gauge from AGCO as I felt the aftermarket ones didn't quite look right.
Edited by garden_guy - 28 May 2021 at 9:23am |
55allis
Posted: 28 May 2021 at 8:59pm |
I got all brand new knobs and gauges other than that oil pressure gauge they look like original. I will try to get a picture of the tractor later.
55allis
Thanks(1)
Posted: 28 May 2021 at 10:10pm |
![]() Pictures as I promised. |
55allis
Posted: 29 May 2021 at 7:14am |
Does anyone know what this spring goes to? It fell off onto the floor when I took the frame rail off. I put a spark plug (only thing I could get my hand on at the time) beside it for sizing.
![]() Edited by 55allis - 29 May 2021 at 7:15am |
IBWD MIke
Posted: 29 May 2021 at 7:41am |
Throttle return spring. Not sure 'return' is the exact right term. It makes the throttle stay where set.
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 2955 |
Posted: 29 May 2021 at 8:27am |
Throttle compensating spring maybe ?
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8611 |
Posted: 29 May 2021 at 9:08am |
Not a return....throttle won't stay open without it. After adding D17 gov spring to 45 it needed two of those to stay at high idle.
Edited by SteveM C/IL - 29 May 2021 at 9:10am |
JTOOL
Silver Level Access
Posted: 29 May 2021 at 12:01pm |
Maybe brake pedal return spring? Mine fell off when I removed the drivers side frame rail to replace the bolster on my WD45.
55allis
Posted: 30 May 2021 at 11:20pm |
I got both brake return springs on and there is a hook on the throttle linkage so might go to that.
Yesterday I picked up two Allis Chalmers 6’ or 7’ snap coupler sickle mowers which looks very sad. I think I will part one out to get one going.
ac45dave
Posted: 31 May 2021 at 8:03am |
AC720Man
Posted: 31 May 2021 at 8:32pm |
Just replaced Dads series II D15 temp gauge with an Agco gauge made in the USA. 3 times the price of the knock offs but it looks just like the original. I have heard the Heritage gauges are pretty close but I have never tried one. Do not waste your money on a knock off, you will be disappointed. Trust me, I know, I ordered one and immediately sent it back at my cost.
Page <123> |
