1948 "C" wide front |
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Topic: 1948 "C" wide frontPosted: 26 Sep 2009 at 9:39pm |
Wide front C's are much more common out here in the mountain areas....I have seen a lot more of them than the narrow fronts....
Joined: 11 Sep 2009 Location: illinois Points: 89298 |
Posted: 26 Sep 2009 at 9:32pm |
DIfferences in a B and C-----------
The B is about 5 feet wide outside to outside the rear tires. The gear box below the gas tank has an arm that points straight down. It has a ball socke on the end of the amr. The steering rod goes to the left front wheek king pin and sets over another ball socket. The wide front can be wish bone, or tube type. There was not a narrow front end.
--THe C is about 6 feet wided outside to outside the rear tires. THE steering box below the gas tank has an arm that points upward. The steering rod attaches to the arm with a ball joint like used on a car steering arm. The steering rod goes to a second gear box arm under the gas tank. The radiator wraparound is notched for this second arm. The steering on the C is done thru this second gear box under the gas tank thru a set of bevel gears. Most C tractors were narrow front end, but some had the wide box front end. Wishbone axles were NOT standard on the C.
GBACBFan
Joined: 11 Sep 2009 Location: Green Bay WI Points: 2662 |
Posted: 26 Sep 2009 at 8:47pm |
Charlie, you're probably correct, but the eccentrics on the B and C rear rims was not one of A-C's better ideas. The loop rims are easier to use, and SAFER by a long shot. Unless your doing a pure restoration, EdK is on the right track.
are genuine." - Mark Twain |
RichinWis
Joined: 11 Sep 2009 Location: Deforest Wis Points: 691 |
Posted: 26 Sep 2009 at 8:25pm |
In case you were not aware------a C wide front is not exactly the same as a CA wide front. There are some major differences parked side by side.
David Gantt N.C.
Joined: 12 Sep 2009 Location: North Carolina Points: 379 |
Posted: 26 Sep 2009 at 7:12pm |
Welcome, they are great little tractors, if its a true wide front C I would jump on it
CTuckerNWIL
Posted: 26 Sep 2009 at 6:51pm |
The rear wheels are bolt on replacements for the "fall-off" original types. These rims don't fall off if properly maintained. It's kinda like the guy that grinds it into 3rd every time and complains about the bad design of the transmission. JMHO
EdK
Joined: 12 Sep 2009 Location: Newcastle, CA Points: 223 |
Posted: 26 Sep 2009 at 6:41pm |
Here's a picture of a wide fron 1948C. The seat is not original. The magneto ignition has been replaced by a distrbutor ignition. The rear wheels are bolt on replacements for the "fall-off" original types. Other than some other non original parts your 1948C should look similar.
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9693 |
Posted: 26 Sep 2009 at 3:38pm |
just to add to Jacobs info the bottom pic he showed is exactly what a c wide front and steering would look like also the rear wheels would be 5 bolt with dish shaped centers. Most B's had a big nut in the center holding the center to the axle.
Jacob (WI,ND)
Joined: 11 Sep 2009 Location: Kenmare, ND Points: 1249 |
Posted: 26 Sep 2009 at 9:33am |
Here is a pic of a B wishbone front end (on right, that's a IB on the left):
![]() Now I also need to mention that the late B's could come with adjustable wide front ends like this:
![]() The C wide fronts looked about the same. So the eastest way to ID is to get the tractor number from the shift handle. (that is assuming it is not a hodge-podge of B and C parts, which is very possible, since most of the B, C, CA parts are interchangable, though not nessesarily correct.)
Also look at the final drives. If they are narrow, its a B. If wide, it's a C.
And just FYI, if they really dont know what they have, it MAY also be a CA, which can be easily ID'd by its four forward speed tranny and spinout rear rims.
Here is a pic of a wide front CA:
![]() Hope this helps some, again, just ask questions if I confused you. And as a PS, I just stold these pics from the web, they arnt mine (although some of these are from members here. Pic stold from here:)
Edited by Jacob (WI,ND) - 26 Sep 2009 at 9:36am |
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45 |
Jacob (WI,ND)
Posted: 26 Sep 2009 at 9:09am |
Hi,
Identifing what you have is relatively easy once a few things are known. The easyest way would be to post a couple of pics of the tractor here, you'll get all the info you could need. But a good discription is next best.
What does the wide front look like? If it is a "wishbone" front like a B then at least the front is a B. C's did not come with wishbone front ends. The C wide fronts had a tubular front.
Also look for the tractor number next to the shifter handle, it should be C followed by a series of numbers if its a C. BXXX if a B, etc...
You can referance the numbers here:
As well as many other places on the web, and in books, to find out what year tractor you have.
Bryans website:
Is good for referancing serial numbers, locations of serial numbers, engine numbers, engine block numbers, etc... it's worth a look around once you know what to look for, its easy to find the year the tractor was made.
As for mags, I'm no expert, but there are many others here that are. Fixing them is usually relatively easy, sometimes it's just a matter of claning the points, etc... I wouldn't let a non working mag be a deciding factor on purchasing the tractor, but you can use it to deal on the price some...
Good luck, I have two C's now, and I can say they are fun little tractors. Any other questions, just ask!
Edited by Jacob (WI,ND) - 26 Sep 2009 at 5:14pm |
Jacob Swanson
orange man
Posted: 26 Sep 2009 at 8:51am |
I am new to AC and am presently looking at a "C" that has a wide front end. I have not found much info on these and question if it is a mislabeled "B" or if it is truley a "C". I have been told that this tractor has a mag and it doesn't work. Can anyone tell me how hard this is to fix. Thanks
