1948 Allis Chalmers grader |
Brinkley70
Topic: 1948 Allis Chalmers graderPosted: 11 Aug 2025 at 9:00pm |
Hi all, I had an arm break on my grader. I'm wondering if anyone has a parts machine? It's the arm that attaches to the gear box that lowers one side of blade. I caught a big rock just under the surface and it broke in half at both keyway's. Here's a picture of part.
It looks to be all cast so I don't think a weld/strap would stand a chance. Thanks for any help. Thomas |
Joined: 11 Sep 2009 Location: illinois Points: 90826 |
Posted: 11 Aug 2025 at 9:04pm |
Cast iron would be brittle and break... It MIGHT be cast steel... and could be welded, if you dont find a replacement..
Brinkley70
Posted: 11 Aug 2025 at 9:05pm |
Here's a pic of actual part that broke.
Brinkley70
Posted: 11 Aug 2025 at 9:06pm |
Yeah that's what I thinking.
Posted: 11 Aug 2025 at 10:06pm |
Sandblast - Wire brush till clean and wash with soap/ water.. or gasoline...i would bevel the crack on the OUTSIDE so it goes to a thin lip or edge on the ID... clamp it around a brass or aluminum tube so it is ROUND and right size.. or you can finish grind the inside with a die grinder later if you dont have a tube.... Preheat it with a propane or gas torch IN THE WELD AREA up to 200 degrees or better.. The preheat is good and it will drive off any oil or residue... I always use 7018 stick rod on DC when i weld cast steel... Your milage may vary.
![]() Edited by steve(ill) - 11 Aug 2025 at 10:13pm |
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1125 |
Posted: 12 Aug 2025 at 6:34am |
Call Wellers tractor salvage in Kansas 800 255 9325
Edited by im4racin - 12 Aug 2025 at 6:34am |
