1947 WC Back Fires
jrsinn83 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrsinn83 Quote  Post ReplyReply Direct Link To This Post Topic: 1947 WC Back Fires
    Posted: 24 Jul 2012 at 6:20pm
My tractor is backfiring. I'm in the process of getting my tractor started and not going good. My tractor has a distributor so what adjustments do I need to make to stop the backfiring and getting my tractor started?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2012 at 6:41pm
Take the plugs out, turn the engine by hand with your thumb over the front plug hole till you feel compression build up. Now bring the engine to Top Dead Center by turning till the set screw on the front pulley is straight down. Take the dist cap off and see where it is pointing. Number 1 plug wire goes where the rotor is pointing. Now watch the rotor as you turn the engine (in the right direction I hope) and put plug wires in 1243 order in the direction of rotation.
 I would bet money you have 2 wires switched around right now, which causes back firing.
OrangePowerGA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangePowerGA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2012 at 6:44pm
Carb set too lean.
AC - WD
JD - 650
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrsinn83 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2012 at 6:48pm
I talked to a guy I worked with who is convinced that there is pre-determined numbers for the distributor cap? Is this true.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrsinn83 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2012 at 6:49pm
Whats the fix for the carb? I believe mine is a marvel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2012 at 6:53pm
Absolutely NOT. Number one can be any one of the 4 holes depending on how the distributor is installed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jrsinn83 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2012 at 6:55pm
Yea I thought he was nuts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2012 at 7:01pm
Some distributor caps have a 1 where number one should be, but if you install it wrong, 1 won't fire there.
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2012 at 9:33pm
the old way to do it was to start the tractor and run it at full throttle, with the distributor bolts loosend turn it by hand untill she runs smooth. that's how I did my WD45 and it runs perfect
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2012 at 9:34pm
SLIGHTLY LOOSEND.
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2012 at 12:14am
That don't work if you have 2 wires crossedWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2012 at 6:39am
Don't forget that worn points don't help your situation and are cheap and easy to replace.
Edited by Brian Jasper co. Ia - 25 Jul 2012 at 6:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2012 at 7:00am
Make sure your firing order is correct as Charlie mentioned. Once you determined that it is correct, give the darn thing a tune-up! Its pretty cheap to tune it up. Plugs, points, Cap n rotor & condenser and see how she runs then. Splurge and put a GOOD set of spark plug wires on it to. And not those POS sets with the push-on ends either. Might be all the old girl needs, just a little love and attention....  Heart
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2012 at 7:36am
Forgive my ignorance, but don't all spark plug wires have push on ends? They snap over the plug? How else would you attatch them to the plug?
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2012 at 11:12am
I'm talking on the Distributor side of the wire, not the spark plug side. The cheapo sets have a little barbed end that you install on the end of the wire. Junk. That's why most of those are $8-$10 bucks for a set of four. For longevity, good contact, and service life you want the crimp-on style like we make, or a few other mfr's so if you need to remove a wire from the Distributor cap side, you don't rip the crappy barb out of the wire jacket and the barb is now stuck in the cap....  Thumbs Down
