1945 G model Carburetor
cabinfourus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinfourus Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 8:39am
Does it have the wrong carburetor on it?
I have thought this from the start.
Can someone confirm the firing order for me, and the cylinder order starting from the fan?
Firing order 1342
Cylinder order from fan 1234
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinfourus Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 8:45am
I did another leak down test and it was good. No air coming from anywhere at all. I used 100 psi.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinfourus Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 8:49am
I just ordered a capacitor for this thing. Who knows at this point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinfourus Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 9:00am
So, since the other day, this little tractor has not run at all. It would run for a few seconds, but act like it was running out of fuel and die. I pulled the carburetor back off and completely went through it. I even replaced the main jet with a new one. I think it is time to slow down, get back to basics, and see what I am missing.
When setting the timing, I put the number one cylinder to top dead center, and the mark on the crank pulley is at 6 o' clock position. I then adjust the distributor to where the points are starting to open on number one. I did notice the points are not contacting evenly. I plan to fix this today. After setting the timing, I set the points to .020. I OHM tested my plug wires and they are all good. I adjusted the carb main jet to one full turn out, and the air mixture to 1.5 turns out. I am waiting on new 295 spark plugs, and a capacitor for the points. I performed a leak down test, compression test, and checked the valve adjustment. All three were good.
If this little tractor doesn't run this time, I plan to set it on fire. (j/k)
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinfourus Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 9:06am
Is the number one cylinder located just behind the radiator, or near the crank pulley?
Are the cylinders in a 1234 order starting from the radiator?
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2025 at 11:07am
first, that is a replacement aftermarket carb,
as for firing order-
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinfourus Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2025 at 2:17pm
So it would seem, someone has wired it backwards.
I will rewire it today, and post my results.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinfourus Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2025 at 4:53pm
I want to update this thread, in case anyone else runs into this problem.
Someone had the timing out and the plugs wired backwards.
Now, each time I pull the starter, she starts up and runs beautifully.
Thank you all for the help and info, and I promise you, I won't be working on anymore in the future. I will stick to cars. lol
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2025 at 6:21pm
John, most cars have engines too and they can all have their own set of issues to make them run properly. After going through the Allis engine,I think you can now appreciate the simplicity of their design and if you had to do it again, it would be much easier to diagnose an get running. Remember the Allis edict,KNOWLEDGE IS POWER! Glad you got her going.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2025 at 6:27pm
Each company has their own timing and cylinder order - fire... 1243, or  1324 are common.. Dont feel bad.... its easy once you know WHAT your working on !!
This page was generated in 0.309 seconds.
