1938 allis b
rtomlinson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtomlinson Quote  Post ReplyReply Direct Link To This Post Topic: 1938 allis b
    Posted: 17 hours 6 minutes ago at 5:24pm
How do U remove throw out bearing cover
On PTO I can not locate fill & drain plug to put a new cup of oil in.
For air cleaner should U just submerged the entire canister
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 32 minutes ago at 5:58pm
the tin cover under the clutch just prys off.. Couple small fingers WEDGE it in...
the transmission, differential and PTO are one big housing.. 3 drain plugs on the bottom, but only ONE FILL PLUG... like a 1 inch pipe plug by your left foot on the side of the transmission..fill to the bottom thread... about 7-8 quarts of UTF or 20wt oil.. ... if you dont have hydraulics, its POSSIBLE that the housing has GEAR LUBE in it.. If your changing the oil, it would be better to have a lighter weight oil to get up to the upper shaft bearings..
air cleaner cup should be about half full... there should be a couple marks on the cup.. or there is a center  stand tube welded into the cup.. fill it up to the two SLOSH holes... that keeps the oil from sloshing around when you go up and down a hill.
Edited by steve(ill) - 16 hours 30 minutes ago at 6:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 27 minutes ago at 6:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtomlinson Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 36 minutes ago at 6:54pm
Thanks,
I get the 3 drain plugs, when I drain the tran. Got lots of water when diff. Drain more oil & water, PTO got nothing I stuck scredriver I PTO hole just got brown gunk on long scredriver.
I empty the port tran.first
I will fill with D.F
& Let sit maybe drive 10 min.
But some where I read U should drain the pto on the housing somewhere. If I had that much water in tran etc. I thought I should find & drain U only add a cup of oil if U find it.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtomlinson Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 34 minutes ago at 6:56pm
I do have hyd & pulluy
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 26 minutes ago at 8:04pm
the gasket between the differential and the PTO housing sticks up a couple inches... When the tractor is running  DOWN HILL, this gasket traps a quart of oil in the hydraulic / PTO housing so  you can still run the hydraulics... iF you drain the trans then the differential, then the PTO, you will only get a couple cups or a quart from the PTO area...
the water in the transmission came from leakage around the rubber boot /seal on the shift lever.. It will sink to the bottom and possibly never get into the hydraulic PTO area...  Your OK... just flush and refill..
Edited by steve(ill) - 14 hours 24 minutes ago at 8:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtomlinson Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 2 minutes ago at 9:28pm
Thanks for your time & knowledge
It runs, just a couple more things to do before first ride.
I bought it 12/23/25
Brakes might be another issue?? I shopping for used rear tires.
Thanks again
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 9 minutes ago at 8:21am
Not uncommon for Brakes to be come oil soaked.. There is a 1 inch drain hole in the housing below the brake drum. This normally gets plugged up with mud and mouse nest.. The  Axle seals leak over  70 years and this builds up on the brake band.. Then they dont work.. Probably worn out anyway..  To replace , you park under a beam in the garage. take off the hardware and air chisle out the pins.. Connect a small comealong to one end of the shoe and PULL.... thats after you get rid of the mouse nest and mud.... wrap a #9 wire on the new band and pull it thru the housing and around the drum..
Edited by steve(ill) - 2 hours 9 minutes ago at 8:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtomlinson Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 26 minutes ago at 9:04am
U the Man ! Thanks a bunch !
