1937 M crawler with pic
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: 1937 M crawler with pic
    Posted: 17 Jun 2017 at 4:06pm
I'm looking T a 1937 m for sale. It's dual fuel and needs a starting tank. This thing looks to be very low hrs and in extremely good shape. I've seen it running ad a show about 5 years ago but it hasn't ran since. Motor isn't stuck and feels like good compression. He has all the original books and some kind of bog oil/grease can that comes with it. Hes asking 3500
Edited by Thad in AR. - 23 Jun 2017 at 8:57pm
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 5:30pm
Sitting that long the steering clutches may be stuck and they are the last part you come to when tearing it apart. Not sure if you can pull it to see if the clutches are working or not?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 6:10pm
I don't know if it means anything but it was just recently pulled out by the road to sell. it was sitting in a little shed until a couple weeks ago. Does this mean the steering clutches aren't stuck??? The owner is getting old and in bad health and doesn't remember much about it anymore.
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 7:02pm
I'm just guessing but I would guess if the steering clutches were stuck there would be two ditches about the same width as the tracks leading up to where the machine stopped.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 8:55pm
Take someone with you that knows about tracks and undercarriage. I,d be more concerned about that than the clutches. At $3500 might be a tad high but if straight , not too far off the mark.Does it have a belt pulley,pto, or hydraulics. Starter,lights , generator and battery? All can ad to price. I would be very interested in the grease can. Not many of those around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 9:04pm
It has PTO no blade or hydraulics. I see a pulley on the shaft that runs the magnito. I assume for a generator. It has no nstarter but a plate over the starter hole. I was wondering if it would have a ring gear on the flywheel? I looked at all the tracks and sprockets. Nothing has what looks like any wear at all. The draw bar hole is perfectly round.  I don't know crawlers but this thing appears to be low har and very slick.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2017 at 9:29pm
It being a 37, probably has starter gear. And yes, pulley on mag side is for generator but I have seen several that had a starter and no charging system.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2017 at 7:58am
Suppose this thing has a ring gear, would it be hard to find a starter to fit it??
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2017 at 8:05am
I see lots of M's on craigslist, and sure would like to have one someday. On craigslist, they are listed anywhere from 1,500 to 6 grand. From what I am hearing, this isn't a bad buy. Darrel
Bob (IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob (IN) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2017 at 9:01am
The steering clutches could be stuck and it will roll free becouse main clutch is disengage steering clutches only let it turn right or left as far as a starter you need to find one for a dc case will fit all you need to do is drill the tapered lock hole for the locking bolt I have done this a couple times I have two m crawlers
great-grandpa's wc with picker, 20/35, speed patrol, uc, m crawler, 620, 653 dozer d21 d17 d19
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2017 at 5:37pm
I was just told by my fiance (I hope I spelled that right) that I'm supposed to go pick up that crawler as soon as I get a chance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 8:19am
Thad,
Offer him what you feel is a good fair price and buy it! You want a M and he wants to sell it. Seems simple enough just come up with a price that both are happy with and you become the new owner. Also if you fiancee (sp) says go ahead then I would do it.
Post pictures. Sounds like a good machine, not wore out, like the stuff I drag home!
Edited by Sugarmaker - 19 Jun 2017 at 3:01pm
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 9:16am
thad.  I believe Fred in Pa has stated that a DC case starter will fit and work just need to drill a new locating hole in the nose?  orginal starters were autolites i believe the DC case is a delco?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 5:16pm
Thad,
I agree Chris this thing is much nicer than most of the stuff you and I drag home. Sounds like the fiance (SP) done paid fer it. How can I pass that deal up. Wonder what it'll cost me in the long run??? LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 7:33pm
Thad,
 It will be priceless!
Cant wait to see the pictures of your new toy!
Norm Meinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 10:45pm
I have rebuilt starters on hand for the M and U, also for A
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2017 at 12:33am
Take a picture of her sitting on it, in a bathing suit!
There has been an M on the Denver CL for months but now that I look, it's gone, think they were down to $6,000 from $7,000 a few months ago.
BTW there is a D17 Diesel in Estes Park, just listed, $5,000, needs battery's poor repaint job, lots of poor masking on the wheels, expect better for 5 grand!
Edited by JohnCO - 20 Jun 2017 at 12:36am
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2017 at 8:17pm
She followed us home tonight. Kind of heavy for such a little critter. Pics to follow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2017 at 8:55pm
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2017 at 9:21pm
nice Thad!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2017 at 10:15pm
Way to go !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 4:52pm
I have a few questions about the ole beast. Can I get original looking seat cushons? It has the bottom only but I see wher sides and a back bolted on and saw them on a brocure that came with it. Would it have a muffler or just a straight pipe? It needs a new starting tank (its ditsilate) would one work from a WC such as the repro nes I've seen for sale? There will be many more questions.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 8:13pm
If you do a full on restoration John  Hahn in Idaho makes the crawler seats to look original. But will cost $250 to $500 with arm rests and all.
hahnseats@gmail.com
208.924.5538
208.924.7924 fax
509 E Main Craigmont ID 83523
For a working tractor make your own. Plywood for base and back,used foam from a couch or mattress,buy vinyl or canvas from upholstery  shop. Use staple gun to attach to one side,fold like rapping a package. The hard part on this is figuring out hardware to attach back rest. Need to do some testing of what will be comfortable to operator,in the height of seat and leg room.
On a old Cat the original plywood was getting soft,slapped a new piece of 1/2 plywood on top of old. Took about a day to realize that moved me ahead just enough to that I needed to make more leg room by redoing the seat.
I believe most around here where straight pipe and in our fire season a spark arrester on top.
Edited by Ray54 - 25 Jun 2017 at 9:41pm
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 8:57pm
Ray do you have a phone number for John Hahn I would like to call him on seat and arm rests fro my 35 crawler
everett048 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 1:12am
yes 1 from a WC will fit and Norm M has reproduction tanks.It would have had a straight pipe from factory or a muffler was an option i think.
hth
Edited by everett048 - 26 Jun 2017 at 1:13am
