1936 WC foot brake conversion |
David Terry
Joined: 15 Feb 2015 Location: Lawrenceburg TN Points: 41 |
Topic: 1936 WC foot brake conversionPosted: 08 Mar 2015 at 8:45am |
I'm building a 1936 WC for pulling and I'm worried about being able to steer using the hand brakes. I've seen a conversion kit for a WC but I've not been able to locate one. Can foot brakes off of later models be adapted to the old flat fronts?
Posted: 08 Mar 2015 at 1:10pm |
It only takes four hands to operate a WC........left brake.....right brake......steering wheel.....throttle lever (if the teeth won't hold the lever where you want it).
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2578 |
Posted: 08 Mar 2015 at 5:00pm |
Not really. You can home brew something, but you need a linkage from the foot pedal to the hand lever to operate it. I'm thinking you steer with your knee, left brake, right brake. Back bevel the throttle notches with a file so it'll stay in the GO position. Occasionally I'll see a kit come up for sale, just have to watch for them.
AaronSEIA
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5096 |
Posted: 08 Mar 2015 at 7:48pm |
This is totally off the subject but it reminds me of the first time I was allowed to load cow manure out of a pile with my uncles WC. I was about 12 and the ground sloped (quite steep) away from the barn and manure pile, toward the spreader. Of course the loader was a hand trip and I could barely pull the trip with both hands. On my second load I ran into the side of the spreader, which ended my loading career for a while.
I forgot to add the brakes didn't grab very well and the tractor steered very hard, especially if you happened to get the bucket good and full. A man could have used about 8 hands to load with that tractor!!! Sorry for the rant! |
mike a
Posted: 08 Mar 2015 at 10:09pm |
i got a friction throttle control from a M farmall,its tension adjustable.next,move your seat to the middle of the tractor-i use my hand brakes about twice a season,you wont believe how better the balance is-good luck and have fun!
Kip-Utah
Joined: 14 Sep 2009 Location: Southern Utah Points: 919 |
Posted: 10 Mar 2015 at 8:48pm |
I think that hand brakes on the WC is an advantage. When I'm pulling the hand brakes just seem to be more instinctive than any tractor that I've pulled with footbrakes...by the time that the front end starts floating I'm usually at full throttle so my hands have nothing else to do!
David Terry
Posted: 11 Mar 2015 at 9:29am |
I think what I'll do is add a extension on the left hand side so I can reach it from the seat easily and then give it a try in this springs pulls. May not be the problem I anticipate. Thanks, Dave
WF owner
Posted: 11 Mar 2015 at 1:52pm |
When I was a young kid, my first tractor driving jobs were on my uncle's WC and my grandfather's WF (which I now own). Of course both had hand brakes. It took me a while to get used to foot brakes on the "big tractors" (WD & WD-45).
One place I do not like hand brakes is loading a tractor on a trailer or truck. I bet you adapt in a hurry. |
AaronSEIA
Posted: 11 Mar 2015 at 3:59pm |
Put an ad in the classifieds. AC made an extension for the hand brake levers when using a cultivator. You could home brew one too if you so desire.
AaronSEIA |
Posted: 11 Mar 2015 at 4:39pm |
I refer to those lever extensions as the "Power Brake" option.
mattb
Posted: 13 Mar 2015 at 9:36am |
we took a brake setup off a wd made a bracket to hold brake shaft and links with swivels on ends and it works decent
ACJake
Joined: 27 Dec 2012 Location: White Deer Pa Points: 103 |
Posted: 15 Mar 2015 at 9:02pm |
at our local pulls you must have a hand on the steering wheel at all times, SO....... when pulling my 36 WC i hook my left arm through the steering wheel spokes and use it to control the right brake and made a special bent adaptor to control the left brake with my right arm. sounds complicated but it works for me. I pull in the 3 1/2 mph class so Im not going boogity boogity down the track
3 WC's, 2 WD's, 3 WD-5's, D-14 w/HenryBackhoe, D-17, 4 D-19's, 185, 190XTsIII, 200, 210, 7010, 10 L&G Allis's. Nunn Better Farms Bleed Orange!!!!!
allismanamp
Posted: 15 Mar 2015 at 9:08pm |
Anyone ever used WD brake pedels on a WC?
~AMP~
