1920H deck belt
rrhead(SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Topic: 1920H deck belt
    Posted: 16 Jul 2018 at 9:15pm
Several years ago, I changed the 60" deck so all the blades turned the same way. I need a new belt and do not remember where and what size I used. Someone was very helpful with this change over on here, but I do not remember who that was, either. I had a parts store measure it and it is Double V 1/2 inch by 127 1/2 inches now. If anyone can help me with finding the correct belt, I would be very grateful. Thank you, rrhead(SD)
Edited by rrhead(SD) - 16 Jul 2018 at 9:16pm
2 WDs,WD45,D-14,D-17,D-19D,180,7020,6080FWA,6080 2wd, 6080 2wd(cab),8050FWA,8550,4W-305,Massey 8250. Gleaner L3, R62 &R65 Agco-Allis 1616H & 1920H, AC 720, Terra-Tiger
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2018 at 9:48pm
I think I found the number for belt I have. By looking on the internet, it seems to be AA124. If someone could verify this, I think I can get one in Sioux Falls. Thanks, rrhead(SD)
Richmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richmar Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2018 at 8:03am
rrhead (sd)
The belt number for your mower is 1674570   That is a simplicity number  and or  an  agco number.
The  blade number is 1721447   (3 used)
Rich
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2018 at 4:40pm
Thank you for the info. Found a belt locally. It was a tight fit, but got it to work. rrhead(SD)
