1920 D/A fuel pump- ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 1920 D/A fuel pump- ???
    Posted: Yesterday at 7:48pm
1920 D/A - 20 HP Kohler- new gas filter, new air filter- runs good for a bit then acts like it runs out of gas ; choke it , it pulls it thru but not up to top speed- theres a box looking thing / pump that the gas line is connected too - before the carb- any numbers or info on this ??? Thanks!!
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 54 minutes ago at 11:08am
Disconnect the existing fuel line between the fuel pump and the carb. Connect a new line from a test tank to the carburetor fuel inlet. Fuel the test tank with fresh gas.  The described system bypasses the existing. If the engine runs out fine, then you likely have a restriction of fuel flow or a dying pump or both.
~ Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 40 minutes ago at 3:22pm
Been mesing with it - it will run on Carb cleaner so leaning on  fuel delivery - for sure, gonna put a low pressure electric fuel pump on to at least get the grass cut
Edited by DougG - 3 hours 39 minutes ago at 3:23pm
