190XT
SD Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SD Allis Quote  Post ReplyReply Direct Link To This Post Topic: 190XT
    Posted: 04 Apr 2017 at 3:28pm
Can someone tell me how wide a 190XT is?
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 3:56pm
Depends how to the tires are set.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 3:57pm
Depends on where the wheels are set at and how wide the tires are. 60 inch tread setting will get you about 80 inches wide. If the wheels are set wide, it will be 9 feet or better.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2017 at 5:16pm
My tire are set about as far in as possible. 18.4x34 radials. It's 86" wide at the tread and the axles are 88" end to end. It's 84" wide at the tread not touching the ground. The radial bulge is about 2" I'm currently running 10 psi. Not loaded tires with 1000 lb wheel wieght on each side and a cab installed.
Edited by Dakota Dave - 04 Apr 2017 at 8:18pm
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 6:49am
Dave I think you need to add about 6 psi to your tires. 10 isn't good for the sidewalls on heavy pulls.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 7:58am
The heaviest pull its done is a 6' finish mower. It's a yard tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SD Allis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2017 at 9:42pm
Thanks Fellas
This page was generated in 0.083 seconds.
