190XT wheels and tires
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: 190XT wheels and tires
    Posted: 09 May 2023 at 10:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2023 at 10:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2023 at 10:07pm
Wheels and tires off my 190XT. BKT tires are like new, 7.5-16. $250
keithpearson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote keithpearson Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2023 at 11:09am
What is your location?
WD45,160 6040,D14,D15,D17,D19,D21,and still looking for more
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2023 at 12:00pm
Shenandoah Va. There is a fasten all store about 50 minutes away if that helps. Not sure how much it would cost you to ship?
Post Options Post Options   Thanks (0) Thanks(0)   Quote keithpearson Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2023 at 12:24pm
Do you know what the offset of the rim is?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2023 at 6:27pm
I do not but I can get some measurements next week. They are factory wheels, I just went to wide wheels and tires like a 200.
Post Options Post Options   Thanks (0) Thanks(0)   Quote keithpearson Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2023 at 6:58pm
I need a 4" offset. They are going on a narrow front 180
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2023 at 9:44am
I doubt it is a 4 in offset. Offset is the distance form the centerline. It may be 4 inch backset.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2023 at 10:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2023 at 10:36am
Looks like 4 1/4” measured from the back of the hub to the wheel rim.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2023 at 8:38pm
That's not the offset. Offset is the difference between the front and back measurement. Wheel measurements are also to the inside of the bead. You never said what width the wheel is.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2023 at 8:18am
If you weren't so far away I'd buy them just in case something showed up that needed rubber.
Post Options Post Options   Thanks (0) Thanks(0)   Quote keithpearson Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2023 at 3:28pm
Found what I was looking for closer but you do have what I was looking for in the rim. Thanks for your time..
