190XT water pump |
TedN ![]() Bronze Level ![]() Joined: 30 Apr 2025 Location: Central WA Points: 3 |
![]() ![]() ![]() ![]() ![]() Posted: 18 hours 7 minutes ago at 11:19am |
I'm getting ready to change the water pump on a recently purchased 190XT diesel. I realized that even though I have changed the water pump on my other 190XT, it has had an engine swap and has a different pump so I haven't ever changed one on a 190XT engine. What seals the bypass tube? It looks like a compression ferrule from what I can find, but the parts book isn't clear. If it is a compression ferrule do I need to replace them?
Ted |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21400 |
Re-use what you have. Use some penetrating oil and everything. Do NOT cross thread things !
Thank you for that, I thought that would be the accepted procedure but not a job I want to do twice.
Ted |
