190XT vs 7010
Gary(VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Topic: 190XT vs 7010
    Posted: 22 Aug 2020 at 8:23am
Any there any changes you need to make to a engine from a 7010 to go into a 190?
Thanks
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2020 at 8:35am
Several. Rear engine plate, rear crank seal and flywheel will swap between the engines. Front timing cover, front engine plate won't work because you need a way to drive your 190XT hydraulic pump and fit in-between the side frames and still use the newer DM-4 injection pump.  Oil pan and oil pump are too deep and will hit your front axle, so the axle has to be moved or change the oil pan/oil pump. Water pump if different and has the lower hose on the wrong side.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2020 at 9:12am
Thanks Dr. Allis
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2020 at 10:07am
Would a late 200 front axle assembly fit the XT with the deeper 7010 oil pan and pump?
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2020 at 10:29am
You would need the front support from the 200. It would raise the front of the tractor. The 200 and 7010 used 38 inch wheels on the rear. The 190 normally had 34 in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2020 at 5:16pm
The front engine plate needs to come from a model 7000 tractor to have a place to mount the hydraulic pump, and still use the DM-4 injection pump fuel system. This front plate will also fit the side frames as it is. If you find one of those, get the timing cover too.
