190XT VS 4020
ALLISMAN32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALLISMAN32 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2012 at 8:00pm
Driven both and they are both good tractors, but ill take an xt or 200 any day over the Deere. Cant stand the annoying hydraulic pump rattle that all the Deere tractors make. The platform on the A-C is far better for carrying some chains, hand tools and handyman jack than the Deere ever hoped to be. For sheer power and torque the A-C wins again. Dad said he had one customer with both tractors and plowing the only way the Deere could keep up was after the installation of a torque topper lp injection kit. The hydraulics are smoother on the A-C . Never really thought the steering was that bad on A-C you do need to keep the front ends greased on any tractor or they steer terrible. Deere spindles are no better than the A-C, thats why Deere has all the holes in their tie rods so you can realign the front wheel after the spindle twists. The closed center system on the Deere is nice for modern equipment and most of the industry has adopted it now, although i believe a WD Allis first incorporated a closed center system so really nothing new! Kudos to the Deere on road speed too, XT's and all the A-C's  of that design are truly snails. Differential lock is also another nice feature as well as the hydraulic brakes on the 4020. Long live the orange tractors from West Allis!!!!!!
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 4:58pm
No one has mentioned the number 1 reason 4020s are so popular.  If you went from a 2 cylinder to that you'd think it was great too!
LazyDFarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LazyDFarms Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 8:23pm
As I can see this is a very heated debate!  I have run both but own an XT and use it almost exclusively on my operation.  So I must be a little byus, as this is an allis website.
Butt...  like said above this site is great becuase you are allowed "tell it like it is".
What I am about to say, are words I will die by on the situation.  An old farmer I knew had both tractors.  He told me "When I wanted to work in comfort, I took the 4020.  When I wanted to work and get done,  I took the XT."
I'VE DONE MORE WITH LESS!!
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 9:58pm
Gerald,
You should be able to get any of the sync 4020's to that 3rd reverse if you slam it from 4th down past 7th.  Have done it on the ones we had/still have-kids will try anything once.  Deere designed it for safety reasons I heard not to be able to shift to the 3rd reverse.  It will go about as fast in reverse as 7th forward...
I grew up on sync 4020's and have no problem shifting any of them on the go as long as going downhill and not under load :)
Thanks
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 11:09pm
It takes worn linkage to get to 3rd reverse. It was included in the 4010. It is fast moving and some say the gears can't handle the transmission input torque well either so adding leads to broken transmission gears. The gearing in the 4020 transmission is not simple, nearly ever gear in the box is used in every operating position, just in different orders. It wasn't designed overnight. The shift lever runs two cams, one in the left position, the other in the right position so lots of combinations are possible.
Gerald J.
ac45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 8:55am
Another negative, on the 4020 is the ealry ones with the split  24/12 volt system, they were hard on batteries, and the generator never seemed to keep up unless you were running wide open,  if you used the lights much and did a lot of stopping and starting you were lucky to get 2 years on a set of  batterys, and alot of times would have to charge them,  On a plus though you can pull start a synchro tractor  you cant do that on an xt    For a useing 4020 your money ahead to convert to 12 volt and put an alternator on it.  This  was remidied with the later console tractors, not sure why they just didn't do it earlier, as they were buliding 2020's with alternators when the 4020 was still 24volt and had a generator.
As far as shifting a syncro, unless the linkage is worn out, if a person can figure it out from the decal with the shift pattern they shouldnt be on a tractor,  forward to reverese shifting is quicker than you could ever imagine  shifting on the allis.
In my opinon the powershift deeres were overated. whil innovative at the time,  it does take about 7 or 8 hp to run that power shift,   From what ive heard a lot of guys could almost add an extra bottom with a synchro tractor while plowing. It is nice for chore, hay bush hogging work though.
Edited by ac45 - 28 Feb 2012 at 9:00am
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 10:44am
Originally posted by Russ SCPA Russ SCPA wrote:
I owned a pair of 190 XT's , have run 4010's, 4020's, 826's, 856's, 966's(owned one of those jewels for entirely too many years), 1850 Oliver as well. Each and every one had strong points and all had weak points.  From personal experience, the AC and Oliver were "torqueier", the IHC's were larger more bulky operating units, and the 966 was the hottest thing I have ever run on operators deck, it was BAD.
From memory if I had to pick
 1   190 XT overall keep it light and run fast it will stay togeather
 2   Oliver 1850,   slower on road, harder to shift, but extremely long design life
 3  4020   corperate back up service
 4   4010  see above
 5   856
 6   966   just a little clumsy, never meet a gallon of fuel it didn't like
 7   826    the hydro sucked entirely too much power away or this one would have been my number 1 choice    tough, tough old birds
i have to agree about the 826, strongest tractor for weight we ever owned was a 826 manual transmission, the german diesel just did not know the meaning of quit, we never owned a 190, and i am sure that there are things that i would like about one, but when the 826 was bought in 1970, the 64 4020 became a wagon puller,
i like old tractors of all colors
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 11:01am
The 12/24 was only on the diesel 4020 though it began with electric start 2 cylinder diesels. It mostly worked though it confused most barn yard electricians who added loads without keeping them balanced and that upset battery charging balance. The biggest fault was the wimpy generator. On the gas and LP it was 12 volts 20 amps and on the diesel 24 volts 10 amps. Which meant you needed to run the tractor and hour or two per start to charge the battery, maybe longer on the diesel and there was no ammeter to let you know it was charging. It didn't take many added lights to absorb all that charging current. I added an ammeter and the voltage regulator was so slow it pulsed the ammeter which bounced from peg to peg, no useful reading. So I converted my gas to an alternator for about the same money as a new regulator, and get several times the battery life because it does charge properly. The solid state regulator is probably the greatest benefit.
The PS did absorb lots of engine power, think about losing that much on a 60 hp 3020 which could be had with PS.
Gerald J.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 11:53am
The XT is superior in every respect because of who made it,,, no other reason needed in this house.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 12:33pm
Never driven either one so can't comment on the tractors.
I am not stick up for Mother Deere or anything, but I will comment and the 12/24 electrical system, which is not as compicated as many think
In a normal gennie system, assuming its positive ground, the current on the negative side of the sine wave is used to charge the batteries, the current on the positive side is dissipated to ground via the ground brush.
The 12/24 GEN has 2 ARM terminals(only one on a normal gen) One is hooked to the positive side of the current and the other to the negative. The 12/24 tractors had 4 6 volt batteries hooked up to make 24 volts. The gen sends 12volts+ out of one terminal and 12volts- out of the other to the batteries. See, the gen is charging 2 of the batteries like they are positive ground and the other 2 like they are negative ground, although like Gerald said, only at 10 amps.
I think maybe I just confused everyone instead of explaing it, but at least it sounds good
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 2:27pm
LOL, baffling them with BS eh? Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 2:34pm
lol.......I guess.....thats how I have it sorted out in my head on how it works.....
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 4:45pm
Don is close but... The 3010, 3020, 4010, and 4020 used two 12 volt batteries. The starter and generator were wired directly to the batteries for 24 volt operation and are 24 volt devices. With solenoid for the starter. The junction of the two batteries was grounded to the chassis allowing positive ground and negative ground loads like lighting, planter monitors, radio, and gauges. Some vintages used a really solid ground, and some used a fuse and blowing that fuse with unbalanced 12 volt loads caused seriously confusing voltage readings to ground and sometimes blew lamps on the low load side.
Its not a lot different in concept than what Thomas Edison used for 120/240 volt DC power in the late 1800s. One side of the street got +120 and the other side got -120. With wound field motors, hot plates, and lamps as the loads they didn't care much about polarity. Some electrolytic "meter" for consumption probably did, but no matter the direction of the electrons, material moved and could be weighed to determine user consumption.
In the tractors, it was important when adding loads to split them and add equally to both batteries so the batteries would charge and discharge evenly. That was so important that the lights on the tractor are divided with twice the circuits, circuit breakers, (or fuses), and switch poles. Edison used two generators in series. His benefit was reduced current and thus voltage drop in the neutral.
In a generator, no current is dissipated for half the sinewave. The commutator connects each armature coil in sequence when its at maximum voltage with the proper polarity for the load. And since the armature coils are in series, the brushes ground the negative side of the armature (for negative ground) and tap off the positive side to the battery. Each coil in the armature generates a sinewave IN the coil but the commutator does mechanical rectification. In the alternator a bank of silicon diodes connects each of the three windings to ground the negative going end and to connect the positive going end to the battery WHEN the generated voltage is at or above the battery voltage and swaps ends each half cycle of the sinewave.
4 6 volt batteries would also work, but it wasn't used in the new generation JD tractors to my knowledge.
Gerald J.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 7:19pm
Yea I remember them 4010s and  4020s.  Typical Deere design,   overcomplicated transmission, prone to wear,  over complicated closed center hyd sytem, over complicated electrical system that didnt work,  and a marginal engine.   They had good brakes and  a comfy seat.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 7:35pm
Well if we are going into bashing mode IH was pretty good too at making things more complicated than needed. Examples are the 3-point hitch on about all IHs and the wide front end. Lots of peices to wear and break. That all said I still can give credit where credit is due. The 706/806 were pretty comfortable to ride and I never seen an Allis diesel or Deere of the 70's or earlier that starts like a 1066. Well Dad's HD11 starts about as good as the 1066. Deere at least used to be most loyal to the American farmer unlike Deutz or AGCO.
Edited by Lonn - 28 Feb 2012 at 7:36pm
Wink
I am a Russian Bot
Post Options Post Options   Thanks (1) Thanks(1)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 8:06pm
Shouldn't leave them out of the logo either I guess?LOLLOLLOL
