190xt turbo oil elbow not sealing
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Topic: 190xt turbo oil elbow not sealing
    Posted: 28 Mar 2023 at 4:38pm
The brass elbow on top of my turbo is leaking I have it as tight as I can and still have it pointing the right way for the oil line. Is there something I could use that's oil and heat proof to seal it with? Thanks
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2023 at 5:49pm
Thread on elbow most likely has a crack through it,
Edited by JPG AUSTRALIA - 28 Mar 2023 at 5:50pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2023 at 8:26pm
I would use red loctite and a new rubber on line.                 MACK
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2023 at 11:09pm
Double check where oil come up & out at threads into turbo housing OR is the fitting itself cracked OR at threads the line couples with?
I've seen all 3 leak, have used 1 1/2 wrap of teflon sealing tape on male thread w/ no isssues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2023 at 3:57pm
It is coming from turbo housing threads
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2023 at 5:16pm
If it's coming from the pipe threads, it needs some kind of goop or thread tape on the threads and brake kleen both the hole and the male threads before assembly. And it has to be tight enough !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2023 at 6:53pm
Is it safe to use regular pipe tape with it going into the turbo? Fully tight puts the outlet of the elbow where the line will not work
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2023 at 10:33pm
Regular teflon tape. Just be sure to keep back from edge of thread so none can get into oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2023 at 7:26am
Can't get the tube connected to it ?? Why? orientation wrong ?? tighten it more. Too far down to not be able to connect the tube ?? Get a NEW elbow fitting that has new threads and it will sit up a little higher.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2023 at 9:12am
The bad part about pipe threads and a 90* fitting. Aimed right almost hand tight, by the time you make another round it gets so tight you feel like it'll break! If you use tape, use caution too. It's so slick it'll turn easier.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2023 at 10:58am
every one is right,  i would try a new fitting and use  loctite 545 hydralic and phenmatic sealer is some very good stuff for some of those problem npt fittings it has high solids in it and is rated for extreme temps if its assembled clean and it can set for a day it can handle 2000psi , but it disasembles like red 270 loctite   545 might only be available through an industrial supplyer like grainger .    also if you have a cracking in your female threads it might take it up.
