190xt transmission dilemma
MadCow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Topic: 190xt transmission dilemma
    Posted: 26 Jan 2026 at 11:16pm
I have a gas 190XT, snap coupler. I prefer snap coupler, and since everything I have is gas, I prefer gas. I also like the sound of it running better. It also doesn't have the weird horse door cab where the one door opens in and the top opens out.
I have a 190XT diesel. 3pt. Recently "overhauled" (don't know exactly what) engine. It has the factory cab with the dorky doors.
However. The diesel doesn't jump any gears. Goes in hard and solid and stays. The gas jumps out of second. Up hill, down hill, load, no load. With a bungie cord hooked up right it's mitigated.
I put maybe 150 hours on all tractors combined a year. And I do like mechanical work. I'm slowly building up and this is the tractor that'll be growing with me. So the question is:
Do I go with the diesel and swap all the snap coupler stuff over? Do I try to swap the transmissions and hitches so the gas has the best of it all? Do I calibrate my bungee cord and wait for a transmission rebuild?
1st, 3rd, 4th, reverse all work fine. And I do really prefer the gas over the diesel.
This is far planning, just changes whether I sell the extra tractor now, or hold on or swap.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2026 at 7:09am
If I were you I'd keep both and fix the tranny in the gas tractor. Can't imagine getting rid of a good running 190 D.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2026 at 8:25am
Those 190 diesels seem to be desirable. I would keep both in their original state. I would like one myself but unfortunately have no use for it.
A&Sfarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote A&Sfarms Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2026 at 1:27pm
Tractor Data says the gas uses 7.2 gal/hour and the diesel uses 5.3 gal/hour at rated speed. Something to consider since you said it will be the tractor you grow with. We are all out here waiting for input costs to come down... Plus the diesel will be cheaper to operate considering it doesn't have transmission problems. Our 7060 sits fairly often because the XT is so much cheaper to run
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2026 at 7:17pm
At least remove the shift cover and take a look. Maybe you just have a broken shift fork? Wouldn't that be nice !!
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2026 at 8:48pm
I had a gas 190XT for a few years used to bale with it,burned about 4 gal/hour
Post Options Post Options   Thanks (0) Thanks(0)   Quote A&Sfarms Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 11 minutes ago at 10:04am
The 7.2 number comes from a dyno test at full load. I'm sure baling doesn't put that much load on the engine. Just using those numbers for comparison. It might not be that large of a difference at all speeds/loads, but its also not insignificant when you look at costs per acre at the end of the year
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 26 minutes ago at 11:49am
Keep the diesel for now to use while you have the gasser torn down for repairs. Once the gasser is fixed, then decide whether or not to keep the diesel.
The difference in fuel costs at ~150 hours per year total time on all of your tractors will be a minor part of your total operating expenses. JMHO, your mileage may vary Big smile
This page was generated in 0.174 seconds.
