190xt Torque Tube Noise
Smeyer87 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smeyer87 Quote  Post ReplyReply Direct Link To This Post Topic: 190xt Torque Tube Noise
    Posted: 10 Feb 2021 at 9:45pm
I have a 190xt that is making a knocking sound in the torque tube. Pulled the PTO housing, hydraulic sump, and cover into the power director tonight. All of the gears look fine and have no missing teeth. Could it possibly be a bearing? Noise completely goes away when clutch is pushed in. Can hear it when tractor is idling in neutral, but is most noticeable in low range or when pto is engaged. Any insight would be amazing. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2021 at 10:19pm
Noise at a slow idle with any kind of cab would be considered somewhat normal, or have we discussed this before?? Throttle up to 1500 noise goes away.
Edited by DrAllis - 10 Feb 2021 at 10:20pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2021 at 10:21pm
you have a tooth off one of the reduction gears. Pull cover where suction tube comes out. Might find a tooth.          MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Smeyer87 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2021 at 12:21pm
Had the cover off last night and there were no metal chunks shiny particles or missing teeth.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2021 at 9:53am
just out of curiosity - does the tractor idle smooth or is it erratic as in the gov washer weight retainer  is bad...  an erratic idle causes all kind of rattles especially if cab equipped as Doc sez..and the PTO is shifted in.  IF the idle is smooth , me thinks you have a gear tooth or brg issue.  - my 2 cents worth..
