190xt timing marks
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Topic: 190xt timing marks
    Posted: 08 Feb 2017 at 9:56am
We're doing an overhaul on a 190xt ser1 . Got the engine torn down but noticed only one stamper mark on crank gear it lines up with cam with key at 12oclock but shouldn't there be one for the idler gear so we can get the pump in correctly?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2017 at 10:41am
not really. Pump is timed to the crank, and internal pump mark, so whatever happens between is not really important.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2017 at 11:38am
I see there is two sets of marks on the idler and a mark on the internal inj pump gear guess I'm. It sure why there is no mark to line up idler to crank so you can then line up pump gear to idler. Picture in the book I have shows 2 marks on crank. How do you get the pump timed to crank with no mark?
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2017 at 12:24pm
Damper pulley or flywheel marks is where an injection pump would be timed to. On some engines the inj pump gear has to be put in "in time" because the gear can't come out of the cover. On AC engines, the gear can come out, so it can be positioned where ever it's needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2017 at 12:26pm
Thanks Head I forgot about that second hole in the cover. I've done several of these engines in frame this is my first total overhaul
