190XT Tie rods |
Post Reply |
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7191 |
Posted: 24 Jun 2019 at 9:37pm |
When I restored my 190XT last year, I put new tie rods on both sides (chinese aftermarket I suspect). When turning sharp left turns, the tie rod end would slide in the tube even though the clamp was as tight as it could go. Played around with it this past weekend and I started by centering the front plate. Now both sides will slide when making their respective turns. I ground a bit of metal out of the clamp to get them to close tighter, but they still slide. I am at a loss here. I am getting tired of having to keep resetting the front wheel toe in. Any assistance would be appreciated.
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7912 |
Them come from AGCO?
DSeries4
Can`t remember. I think I got them from my local AGCO dealer.
Toscani NE SD
Orange Level Joined: 21 Jan 2011 Location: Milbank S.D. Points: 369 |
I have had the same problems with my 180, i also put new ones on and they will slide if i hit a hole or something, remember on here they say to grind off clamp on old tie rods and double them up on new ones, i havn't done this yet but plan to
MACK
Keep the clamps from old tie rods and put on new. New are junk. MACK
Lonn
Orange Level Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29773 |
What MACK said!
Wink I am a Russian Bot |
JK in Pa
Bronze Level Joined: 12 Sep 2009 Location: Dushore, Pa. Points: 159 |
I installed a new pair on my WD last year. I am pretty sure they were Chinese. Really good price. They looked just as good as the the originals, but the split in the female ends were not wide enough. A cutting disc in my right angle grinder took care of that issue in a hurry. Hope this helps.
Joe(TX)
Orange Level Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
I had to do what Mack said.
oldways
Silver Level Joined: 25 Apr 2013 Location: west Ky Points: 507 |
I had this same problem. Drove me crazy !
Post Reply | |
