190XT Tie Rod Removal Problem
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Topic: 190XT Tie Rod Removal Problem
    Posted: 18 Jul 2019 at 8:26am
Tie tie rod broke over weekend and I am having trouble removing the stud from the the cast iron piece.  I have hit it with a small sledge but it isn't moving.  Soaked it with wd45 over night too.  Seems like the rubber protector is embedded into the hole but not sure?  I don't want to break the cast iron piece hammering on it.
I am also having trouble removing the male part from the female part.  It won't budge either.  I am kind of wondering if I shouldn't just replace the female part though while I am replacing the male.  It is probably worn out too.
Just asking if there are any tricks anyone knows about to make this happen?  My thought was to heat it up and that might burn the rubber boot that surrounds the stud?
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 8:35am
Heat will help, don't think a fork will get under the remains to wedge it out of the hole, but might try it. ---Might try a puller and press from the bottom side to force it to loosen in the taper hole. If all else fails, I always went for the heat as last resort.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 10:00am
See if a fork can get under it or someway to put upward pressure on it..... a bottle jack?..... and then give the end of the cast iron a good rap with a heavy hammer. Should pop right out.
Wink
I am a Russian Bot
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 10:22am
I always just take the nut off the tie rod and jack the tractor up...it'll pop loose sooner or later with that much weight on it. Never have broken a steering arm yet either. Those things are some hard stuff!   Rick
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 11:29am
I hit it on the side of the arm towards the spindle. Hit it hard and it will come loose, did a 6060 and a 8010.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 6:35pm
Remove nut,turn spindle so you can hit the tie rod end straight on with a BFH. Few good whacks will release taper. Otherwise you remove wheel and use BIG hammer on one side and whack it on the other with another big hammer.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 7:56pm
PB blaster or Kroil will work better than WD40.
I used a tie rod removal fork on mine. There is also a tie rod removal tool similar pitman arm remover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 9:30pm
Well, I used the jack method and used a hylift Jack on the bottom of the bolt. Got the wheel off of the ground. It did not release though. I let the jack down after about 3 minutes. Removed the jack and hit it twice from the bottom with a small sledge hammer. It came right out. The stud was bent to one side so might have made it stick. I see no easy way to get the male side separated from the female side. I have decided to buy female side since I can feel some slop. I paid $80 from agco for male side. Noticed that all states ag is selling both sides for $42. Going to pay $19 for female side plus shipping. Is the agco version worth another $45 for female side? It is still an inexpensive fix compared to most. If the extra $40 is worth it then maybe I should go that way. As always, appreciated everyone offering up the advice. I was attracted to the jack because hitting things with a hammer has screwed me a free times.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 10:45pm
Big hammer is my best friend. I would think agco parts should be better but they probably came from the same production line as the cheaper ones.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 7:02am
I've taken a few of these off and never broke anything using a hammer. Generally the tie rod has been together still and I have used a pry bar under the tie rod and a big hammer and usually one or two whacks does it. Pressure along with a couple of good whacks will do it. Pressure alone probably not.
When I worked at the Allis shop the foreman told me you can do more harm if your hammer is too small. I've kinda stuck to that thinking for most things needing a hammer.
Wink
I am a Russian Bot
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 2:09pm
I replaced a tie rod on a 200 allis this spring with the new setup from All States Ag PArts. I would NOT reccomend their tie rod! Where the male end slips into the female end, the tolerance is wayyyy to big! You will tighten down the clamp and the tie rod will slide out when you steer the tractor. I had to put a second clamp on it and grind the clamp gap bigger and it was still questionable. Get the AGCO one. If it is like the original size, that would be the way to go.
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 4:14pm
I had to use the clamp off the old tie rod. The ones on the aftermarket ones are not heavy enough. Like was stated earlier, the aftermarket rods are too loose also.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 4:57pm
Spend the extra and get Agco also unless the other side has already been changed do it also as all the slack won’t take long to Kill the other one
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 7:36pm
Dang guys , crank down on the bolts and a spot weld will hold it
200 10and20 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 10and20 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 7:45pm
Fix it with Agco parts and do it right Mickey Mouse parts and Mickey Mouse repairs will get you or someone else hurt or killed!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 8:10pm
A ball joint wedge or removal tool depending on your description worked for me. I did find, that its less expensive from Agco to order the entire assembly than to order each side. I was going to replace both sides at the same time while I had it apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 8:29pm
The easiest and safest method is this: Loosen the nut on the stud several turns. Jack some force against it,just steady pressure, Then hold a 3 lb hammer against the steering arm solid on one side, hit the other with a hammer. It will come right out. The nut keeps it from hitting you in the head. Never had this to fail, the hammer lick temporarily eggs the hole to break it loose. HTH Tracy
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 8:42pm
Kinda glad some of the advice isn't in the OP manual Ermm
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2019 at 7:49am
I bought the agco version. Should arrive Tuesday. I will look at other side and see if I should replace. A really rough hay field created this problem. One thing I noticed was that the replacement has a grease fitting whereas the old one did not. The other side has a grease fitting. Thanks for all the advice.
