190XT series 3 vs 7000 maroon belly hydraulic pump
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Topic: 190XT series 3 vs 7000 maroon belly hydraulic pump
    Posted: 15 Jan 2023 at 2:39pm
Does anyone have any info on the specs and differences between the two. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2023 at 6:28pm
A very late model 190XT dual-pump had gears that were .700" wide and delivered 4.25 GPM to the steering via the priority valve spool. The early 200's were the same. Later 200's and maroon 7000's had .900" wide gears and depending on which tractor delivered 6 GPM (200) or 8 GPM (7000) to the priority circuit. The priority valve spool was set-up to deliver the different GPM's because of hydraulic circuit needs for each specific model. What are you trying to do ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2023 at 6:43pm
My late series 3 pump had a bad main drive shaft and I got a a used maroon pump for next to nothing I want to use instead they look very similar with the exception of the flow devider. My question is can I run the maroon pump instead without any problems? Thanks
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2023 at 6:59pm
Your tractor was set-up for 4.25 GPM for the steering and Power Director/PTO clutch circuit. At a minimum, I'd be checking the P.D. clutch pressures to be sure they aren't too high !!  especially at full throttle. It might be wise to remove any shims inside the priority spool to help cut down on that 8 GPM priority circuit flow. I've never done this, but I don't scare easily.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2023 at 7:34pm
What's the serial number of your 190?
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2023 at 8:18pm
30507
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2023 at 8:21pm
Would there be a problem running a higher gpm pump off of the camshaft? When the original pump went out it locked up and broke the camshaft and the tractor got the updated cam and bolt on gear from a early 7000.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2023 at 8:33pm
no ,  but as Doc stated, the concern is the PS PD flow area.  We just don't want to put more in than can be bypassed w/o upping the pressure.  Follow his advice and test it and see. My bet is the slight wear will drop the GPM to a point it will work and improve the hyd performance ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2023 at 9:14pm
Does anyone know if there's different steering cylinders and orbital for the late 200-7000 maroon with the higher gpm or are they the same as a late 190xt would have?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2023 at 9:31pm
Power steering orbitrol is 70249505 on a 190XT and a maroon 7000.
