190xt series 3 leaking hyd oil
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Topic: 190xt series 3 leaking hyd oil
    Posted: 12 May 2011 at 9:32pm
I have a series 3 xt that started leaking hyd oil out of the belly @ the inspection cover and the hole at the bottom of the clutch it started 2 days ago after a good work out with a 12 shank chisel plow and 40 acres, anyone have any ideas before I start looking, I first thought it was the rear main, because she is new from top to bottom in the engine with about 3 light hours on it when I noticed it, but today I looked at it while dripping and it was hyd oil, and yesterday it took about 2 gal of hyd to fill it up, thanks, Dustin
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2011 at 9:36pm
Seals leaking on front of torque tube shaft. Split at back of engine and make sure there is no end play in shaft.  MACK
