190xt series 3 hydraulic pump |
Allis Magoo ![]() Bronze Level ![]() ![]() Joined: 14 Jan 2014 Location: Md Points: 123 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Feb 2022 at 9:48pm |
Gradually lost rear remotes when brush hogging. Then steering was intermittent. Thinking I'm not getting hydraulic flow out of the pump. No leaks on the suction side. Are the ports on top of the pump for testing? Anyone have some test procedures. I have a flow meter and all the guages. If there are port labels I Can't see any.
Edited by Allis Magoo - 15 Feb 2022 at 9:58pm |
Check oil level first. MACK
Oil was good. Even added a bit to overfill. I did notice if I held the steering occasionally it would build pressure and the wheels would move just a bit. Same when I try to use the remotes to lift. The brush hog would shutter trying to lift every so often.
Edited by Allis Magoo - 17 Feb 2022 at 5:38pm |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21898 |
Two dipsticks. One on the left. One on the right. Hydraulic oil is which one ??
Acdiesel ![]() Orange Level ![]() ![]() Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2576 |
could be low oil.
had the same issue with our 6060, I just put a pressure gage on one of the remotes and only Had about 900 psi max @ 1800 rpm. Replace the pump and everything worked fine. Dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
Just got back and seen this.I was checking around to see where I could tap in and happened to notice the sump was at the torque tube....duh. not sure why I assumed it pulled from the rear when I literally just put this thing together 3 years ago and know better. You know what they say about assumptions! I hope my mistake helps someone find the thread in the future. I will say you guys are good and called it lol. The brush hog cylinder was leaky. Definitely will need to fix that because it obviously leaks more than I thought. Hopefully I didn't pre maturely wear anything. Thanks again for the great advice!
Edited by Allis Magoo - 18 Feb 2022 at 11:48am |
