190XT rear ends
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Topic: 190XT rear ends
    Posted: 30 Mar 2020 at 6:59pm
I know there is the early small axle 190 and 190xt prior serial #9001 and that its internal parts are non inter changeable with the later ones I also know that they did some improvements in the series 3 rear ends. What would I need to look out for when swapping a SN#13,xxx rearend onto a SN#11,000 tractor from the back of the torque tube back (trans,bull gears,pinion and ring gear) into the my tractor has a bad bull gear,bad output shaft bearings,axle bearing and seals,ring and pinion,inputshaft, and 3erd gear is chipped in a dozen spots. My thoughts are take my good PD and put it on a good rearend, some new gaskets and seals bolt it in and let'er run. what would/should I watch out for?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2020 at 9:07pm
Should be a go.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2020 at 9:20pm
ordered the gaskets today we will find out very soon
