190xt pulling hitch
Message Reverse Sort Order
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 190xt pulling hitch
    Posted: 14 Feb 2016 at 3:18pm
Best way ive done was take the original drawbar off, take the thick piece where the original drawbar hangs on with the curve , take the 4 bolts out , flip it over, reinstall the bolts, then have a steel drawbar made 3in wide-3/4 inch thick material with a D ring made of 1 inch thick bar material with at least a 3.5 inch hole; measure the original pin where the drawbar hooks too back to the flipped over mounting point and add 6 inches just to be on the safe side; that will be the new drawbar length, then slide the new drawbar into the original mounting bracket, mark it just so the D Ring hole is flush with the flipped over piece on the back , that's where your hole needs to be in the new drawbar; wish I had a pic its really very easy to do; shim it up to 20 inches, make a strap across the new drawbar bolt it down and your ready to hook;
Justthemechanic190 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justthemechanic190 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2016 at 12:57pm
This will be on a Farm stock puller
2wise4agm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2016 at 6:34am
If you pm me a phone number I can text you some pics of mine. It's just way easier than trying to put them on here.
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2016 at 8:47am
A hitch for a 180 - 185 with the final drives turned back will be different than a hitch for a 190 - 200. Yes the bolt pattern on the rear plate is the same, but the length of the hitch from the plate back is longer for the 180 - 185 to account for the wheel centers being moved rearward.
Edited by O.P.S. Heads - 11 Feb 2016 at 8:52am
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2016 at 7:10am
Wow, the Ace chassis link shows a really nice build. I was totally drooling until I saw it painted. I'm a fan of keeping the stock type decal. But it is still a great looking tractor!
Acllss puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2016 at 7:42pm
Send me your ph. number and I'll text you what we built, mine is on a 180 but same bolt pattern ad a 190.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2016 at 3:19pm
What kind of pulling you doing? Farm, hot farm, or all out getting it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2016 at 8:13am
This may help give you some ideas:
http://www.acechassis.com/200_allis.html
This one is pretty elaborate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justthemechanic190 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2016 at 5:24pm
Does anybody have any pics of their hitches.
