190xt pto noice
Bob (mo) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob (mo) Quote  Post ReplyReply Direct Link To This Post Topic: 190xt pto noice
    Posted: 11 Mar 2010 at 9:05am
My 190xt is making some kind of rattling light knocking sound from the rear end when the pto is engaged the heavyer the load the louder it gets. It stared doing it a couple years ago and is gradually geting worse . Has anyone had this problem or can someone tell me what has gone bad in there ?
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2010 at 11:28am
If it's a 2 speed PTO, then you gears in the 3pt housing (single speeds may have this too, but I'm not for sure on those).  I would start by pulling that housing off.  You will probably want to pull the top cover off and have someone hold the PTO shaft so you don't have it fall out and nick the seal between the rear end and the transmission.
Hurst
1979 Allis Chalmers 7000
5800 Hours
